Ana içeriğe geç
Sony Xperia XZ2 LCD Screen Replacement
Neye ihtiyacın var
  1. Sony Xperia XZ2 LCD Screen Replacement, LCD Screen: adım 1, 3 resimden 1. Sony Xperia XZ2 LCD Screen Replacement, LCD Screen: adım 1, 3 resimden 2. Sony Xperia XZ2 LCD Screen Replacement, LCD Screen: adım 1, 3 resimden 3.
    • Weaken the glue that is keeping the screen in place by heating up the edges of the phone with a hair dryer or heat gun.
    • The phone gets very hot and can hurt the user handling it.
  2. Sony Xperia XZ2 LCD Screen Replacement: adım 2, 3 resimden 1. Sony Xperia XZ2 LCD Screen Replacement: adım 2, 3 resimden 2. Sony Xperia XZ2 LCD Screen Replacement: adım 2, 3 resimden 3.
    • Scrape all the glue from the inside edges by inserting opening picks into the bottom edge of the phone and working your way around the edges.
    • If the glue hardens and becomes difficult to move the plastic around the edges, reheat the phone.
  3. Sony Xperia XZ2 LCD Screen Replacement: adım 3, 2 resimden 1. Sony Xperia XZ2 LCD Screen Replacement: adım 3, 2 resimden 2.
    • Pry open the phone by inserting an opening pick under one of the edges and removing the screen.
    • The screen is still attached by a connector, so do not pull the pieces apart.
  4. Sony Xperia XZ2 LCD Screen Replacement: adım 4, 1 resimden 1.
    Bu adımda kullanılan alet:
    $3.99
    • Remove the bracket covering the connector by grabbing one side of the bracket with angled tweezers and gently pulling it off.
  5. Sony Xperia XZ2 LCD Screen Replacement: adım 5, 1 resimden 1.
    • Gently remove the connector by using a spudger to pop it off.
Sonuç
9 farklı kişi bu kılavuzu tamamladı.
Matthew Ionescu
445 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S19-G5, White Winter 2019 Cal Poly, Team S19-G5, White Winter 2019 üyesi
CPSU-WHITE-W19S19G5
4 Üyeler
12 adet Kılavuz yazıldı
4Kılavuz Yorumları
Worked perfectly fine for my xz2 compact
Maria Schrenk - Yanıt
Hi, someone knows how to glue it back. I read that if I use B-6000 glue it will damage my screen.
Diego Covenas - Yanıt
Double-sided adhesive should do the trick. For example 2mm Universal 3M Adhesive Tape should be preferred to glue.
Célestin Taramarcaz -
The XZ2 Compact has the same screen connector+clip.
My screen came without the upper speaker grille (plastic+fabric). When I tried to remove the glue from the old one the fabric got delaminated from the plastic. Tip: Check if the grille is in place before gluing back!
Dimitrios Josef Moustos - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 13
Son 30 gün: 79
Her zaman: 10,989
