Giriş
If the rear camera of your phone is cracked or not functioning correctly, it may be time for a replacement. This guide will walk you through replacing the rear camera on your Sony Xperia XZ2.
For this guide you will need a hair dryer, opening picks, angled tweezers, a spudger, and a Phillips #00 screwdriver.
Neye ihtiyacın var
Weaken the glue that is keeping the screen in place by heating up the edges of the phone with a hair dryer or heat gun.
Remove the bracket covering the connector by grabbing one side of the bracket with angled tweezers and gently pulling it off.
Take out the twelve 3.5mm screws using the Phillips #00 screwdriver.
Remove the one 3 mm Phillips #00 screws.
Remove the two 1mm Phillips #00 screws.
2 farklı kişi bu kılavuzu tamamladı.
