Giriş
If you need to replace the vibration motor on your phone use this guide. The vibration motor is what vibrates your phone every time you get a notification. If your phone is not vibrating when it should be, you may need to replace the vibration motor. For this guide you will need a spudger. To replace the vibration motor you first need to remove the LCD screen and the battery, which can be moderately difficult.
Neye ihtiyacın var
Weaken the glue that is keeping the screen in place by heating up the edges of the phone with a hair dryer or heat gun.
Bu adımda kullanılan alet:Tweezers$3.99
Remove the bracket covering the connector by grabbing one side of the bracket with angled tweezers and gently pulling it off.
Take out the twelve 3.5mm screws using the Phillips #00 screwdriver.
Remove the one 3 mm Phillips #00 screws.
Remove the two 1mm Phillips #00 screws.
Bir başkası bu kılavuzu tamamladı.
