Ana içeriğe geç
Sony Xperia Z Battery Replacement
Neye ihtiyacın var
  1. Sony Xperia Z Battery Replacement, Battery: adım 1, 3 resimden 1. Sony Xperia Z Battery Replacement, Battery: adım 1, 3 resimden 2. Sony Xperia Z Battery Replacement, Battery: adım 1, 3 resimden 3.
    • Turn hair dryer to medium heat.
    • Slowly move the hair dryer along the seams on the back of the phone. Keep the dryer a few inches away from the case.
    • Circulate the dryer for a full minute to soften the adhesive binding the phone together.
    FixBot'a Sor
    Yorum Ekle
  2. Sony Xperia Z Battery Replacement: adım 2, 1 resimden 1.
    • Once the adhesive is loosened, stick the suction cup to the top-center of the back of your phone and gently pull back.
    • Gently pull back just enough to create a small gap.
    FixBot'a Sor
    Yorum Ekle
  3. Sony Xperia Z Battery Replacement: adım 3, 2 resimden 1. Sony Xperia Z Battery Replacement: adım 3, 2 resimden 2.
    • Once you've opened a small space with the back cover, stick the plastic opening tool into the seam of the phone.
    • Move the tool along the seam to loosen the adhesive.
    FixBot'a Sor
    Yorum Ekle
  4. Sony Xperia Z Battery Replacement: adım 4, 1 resimden 1.
    • Caution: Pulling too vigorously or quickly on the suction cup could snap the back of the phone.
    • Once the adhesive has been adequately loosened, pull back slowly on the suction cup to remove the back panel of the phone.
    • The remaining adhesive should be strong enough to hold the phone together tightly upon reassembly. However, once opened the water resistance of your phone has been compromised.
    FixBot'a Sor
    Yorum Ekle
  5. Sony Xperia Z Battery Replacement: adım 5, 3 resimden 1. Sony Xperia Z Battery Replacement: adım 5, 3 resimden 2. Sony Xperia Z Battery Replacement: adım 5, 3 resimden 3.
    • Now that the back is removed, the battery is visible. You now have access to the battery and its connecting components.
    • With the plastic opening tool, gently remove the connector from the motherboard.
    • Use your fingers to peel the rest of the adhesive away from the phone.
    FixBot'a Sor
    Yorum Ekle
  6. Sony Xperia Z Battery Replacement: adım 6, 3 resimden 1. Sony Xperia Z Battery Replacement: adım 6, 3 resimden 2. Sony Xperia Z Battery Replacement: adım 6, 3 resimden 3.
    • With the plastic opening tool, carefully peel the white adhesive tape up from the bottom of the battery.
    • Use your fingers to peel back the rest of the adhesive tape away from the battery.
    FixBot'a Sor
    Yorum Ekle
  7. Sony Xperia Z Battery Replacement: adım 7, 3 resimden 1. Sony Xperia Z Battery Replacement: adım 7, 3 resimden 2. Sony Xperia Z Battery Replacement: adım 7, 3 resimden 3.
    • Slide the spudger firmly along the right side of the battery, loosening the adhesive between the casing and battery.
    • Flex cables run vertically down the phone underneath the battery and can be damaged easily. Make sure to only place the spudger in the indicated area.
    • Insert the spudger in the bottom-center to further loosen the adhesive. Carefully separate the battery from the phone by sliding the spudger vertically underneath the battery and prying up. This may take some time and work as the adhesive is very strong.
    FixBot'a Sor
    Yorum Ekle
Sonuç
75 farklı kişi bu kılavuzu tamamladı.
Nicolas Avila
1.001 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 2-7, Amido Winter 2014 Cal Poly, Team 2-7, Amido Winter 2014 üyesi
CPSU-AMIDO-W14S2G7
4 Üyeler
35 adet Kılavuz yazıldı
32Kılavuz Yorumları
Does battery replacement ruin the waterproof quality?
mitralal shrestha - Yanıt Paylaş
get reeplacing adheessment from part store.
ooboogah dirti - Yanıt Paylaş
Aft er replacing 2 (so called) waterproof phones due to water damage; I kept my Xperia phone away from water. Sony's claim the phone is weatherproof is a joke.
Kevin Ledbetter - Yanıt Paylaş
I found that a heavy plastic guitar pick (1.0mm or thicker) worked well as a replacement for the plastic opening tools
ryandrake182 - Yanıt Paylaş
Me too... I agree.
remjok - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 19
Son 30 gün: 124
Her zaman: 202,003
