Ana içeriğe geç
Sony Xperia Z Display Assembly Replacement
Neye ihtiyacın var
Videoya Genel Bakış
  1. Sony Xperia Z Display Assembly Replacement, Touch Screen Glass Digitizer & LCD Display: adım 1, 3 resimden 1. Sony Xperia Z Display Assembly Replacement, Touch Screen Glass Digitizer & LCD Display: adım 1, 3 resimden 2. Sony Xperia Z Display Assembly Replacement, Touch Screen Glass Digitizer & LCD Display: adım 1, 3 resimden 3.
    • Warm the Battery cover before disassemble it.
  2. Sony Xperia Z Display Assembly Replacement: adım 2, 3 resimden 1. Sony Xperia Z Display Assembly Replacement: adım 2, 3 resimden 2. Sony Xperia Z Display Assembly Replacement: adım 2, 3 resimden 3.
    • 'Carefully' warm the battery too
  3. Sony Xperia Z Display Assembly Replacement: adım 3, 3 resimden 1. Sony Xperia Z Display Assembly Replacement: adım 3, 3 resimden 2. Sony Xperia Z Display Assembly Replacement: adım 3, 3 resimden 3.
    • Unscrew 4x screws and disconnect 3x flex cables in case to free the mother board.
  4. Sony Xperia Z Display Assembly Replacement: adım 4, 3 resimden 1. Sony Xperia Z Display Assembly Replacement: adım 4, 3 resimden 2. Sony Xperia Z Display Assembly Replacement: adım 4, 3 resimden 3.
    • This are: main Camera, front Camera and antenna wire Flex cable.
    • Now we can remove the Motherboard.
  5. Sony Xperia Z Display Assembly Replacement: adım 5, 3 resimden 1. Sony Xperia Z Display Assembly Replacement: adım 5, 3 resimden 2. Sony Xperia Z Display Assembly Replacement: adım 5, 3 resimden 3.
    • The Headphone connector and the Ringer / Cover / Signal Antenna module.
  6. Sony Xperia Z Display Assembly Replacement: adım 6, 3 resimden 1. Sony Xperia Z Display Assembly Replacement: adım 6, 3 resimden 2. Sony Xperia Z Display Assembly Replacement: adım 6, 3 resimden 3.
    • Disconnect the LCD light flex cable by lifting up the black plastic and removing the flex cable from the right side and we are ready to go.
  7. Sony Xperia Z Display Assembly Replacement: adım 7, 3 resimden 1. Sony Xperia Z Display Assembly Replacement: adım 7, 3 resimden 2. Sony Xperia Z Display Assembly Replacement: adım 7, 3 resimden 3.
    • Warm the Touch screen before you start to disassemble it.
  8. Sony Xperia Z Display Assembly Replacement: adım 8, 3 resimden 1. Sony Xperia Z Display Assembly Replacement: adım 8, 3 resimden 2. Sony Xperia Z Display Assembly Replacement: adım 8, 3 resimden 3.
    • Let's assemble the new spare part.
  9. Sony Xperia Z Display Assembly Replacement: adım 9, 3 resimden 1. Sony Xperia Z Display Assembly Replacement: adım 9, 3 resimden 2. Sony Xperia Z Display Assembly Replacement: adım 9, 3 resimden 3.
Sonuç
76 farklı kişi bu kılavuzu tamamladı.
ZFix
196.598 İtibar
330 adet Kılavuz yazıldı
Ekip
Master Techs Master Techs üyesi
Community
333 Üyeler
1.474 adet Kılavuz yazıldı
54Kılavuz Yorumları
Same procedure with Sony Xperia Z2?
Fredrik - Yanıt Paylaş
How do you warm it? With what and what temperature ?
Jeroen - Yanıt Paylaş
with a hairdryer for like 3 min on high
Peter Tembo - Paylaş
With hair dryer.
ZFix - Yanıt Paylaş
Same procedure with Sony Xperia Z1? Where do i get the screen parts?
chrgro - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 19
Son 30 gün: 127
Her zaman: 240,566
