Ana içeriğe geç
Sony Xperia Z Ultra Front Camera Replacement
Neye ihtiyacın var
    1. Sony Xperia Z Ultra Front Camera Replacement, Battery: adım 1, 1 resimden 1.
      • Use the small suction cup to lift the back panel:
      • Press the small suction cup on to the middle of the back panel.
      FixBot'a Sor
      Yorum Ekle
    2. Sony Xperia Z Ultra Front Camera Replacement: adım 2, 1 resimden 1.
      • While holding the Sony Xperia Z ultra down with your left hand, slightly pull the small suction cup upwards to create a small opening between the back panel and the front panel.
      • While continuing to pull the small suction cup upwards, insert the spudger in the small opening.
      • Pry the front panel downwards with the spudger while continuing to pull the small suction cup upwards.
      FixBot'a Sor
      Yorum Ekle
    3. Sony Xperia Z Ultra Front Camera Replacement: adım 3, 1 resimden 1.
      • Remove the back panel by pulling the small suction cup upwards.
      FixBot'a Sor
      Yorum Ekle
    4. Sony Xperia Z Ultra Front Camera Replacement: adım 4, 1 resimden 1.
      • Remove the following six screws with a Phillips #000 screwdriver:
      • five silver 2.1 mm screws
      • one gold 3.1 mm screw
      FixBot'a Sor
      Yorum Ekle
    5. Sony Xperia Z Ultra Front Camera Replacement: adım 5, 1 resimden 1.
      • Pry the plastic motherboard shield open by placing the spudger under the shield and running it along the edges.
      FixBot'a Sor
      Yorum Ekle
    6. Sony Xperia Z Ultra Front Camera Replacement: adım 6, 1 resimden 1.
      • Use care to remove the motherboard shield, as it may break. The motherboard shield is made of a very thin plastic.
      • Remove the motherboard shield by lifting the lower end upwards first.
      FixBot'a Sor
      Yorum Ekle
    7. Sony Xperia Z Ultra Front Camera Replacement: adım 7, 2 resimden 1. Sony Xperia Z Ultra Front Camera Replacement: adım 7, 2 resimden 2.
      • Detach the battery connection cable by prying it upward with the spudger.
      FixBot'a Sor
      Yorum Ekle
    8. Sony Xperia Z Ultra Front Camera Replacement: adım 8, 1 resimden 1.
      • Pry the upper end of the antenna upwards with the spudger.
      FixBot'a Sor
      Yorum Ekle
    9. Sony Xperia Z Ultra Front Camera Replacement: adım 9, 1 resimden 1.
      • Detach the antenna by pulling the upper end upwards and outwards.
      FixBot'a Sor
      Yorum Ekle
    10. Sony Xperia Z Ultra Front Camera Replacement: adım 10, 1 resimden 1.
      • Insert the spudger underneath the battery and run it back and forth to remove any adhesive.
      FixBot'a Sor
      Yorum Ekle
    11. Sony Xperia Z Ultra Front Camera Replacement: adım 11, 1 resimden 1.
      • Remove the battery from the phone.
      FixBot'a Sor
      Yorum Ekle
    1. Sony Xperia Z Ultra Front Camera Replacement, Front Camera: adım 12, 1 resimden 1.
      • Use care to pry the front camera off, as it can easily be damaged if too much force is used. The connection from the front facing camera to the motherboard is delicate.
      • Pry the connection upwards from the motherboard with the spudger to reveal the front facing camera.
      FixBot'a Sor
      Yorum Ekle
    2. Sony Xperia Z Ultra Front Camera Replacement: adım 13, 1 resimden 1.
      • Remove the front facing camera by pulling upward on the flap to its right .
      FixBot'a Sor
      Yorum Ekle
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Aaron Quinn
930 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 4-6, Maness Fall 2015 Cal Poly, Team 4-6, Maness Fall 2015 üyesi
CPSU-MANESS-F15S4G6
4 Üyeler
25 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 10
Son 30 gün: 26
Her zaman: 2,490
