Giriş
Does your power button not respond? Does your screen remain off even after you press the power button many times? Replacing the motherboard may solve these problems.
Neye ihtiyacın var
Use the small suction cup to lift the back panel:
Press the small suction cup on to the middle of the back panel.
While holding the Sony Xperia Z ultra down with your left hand, slightly pull the small suction cup upwards to create a small opening between the back panel and the front panel.
While continuing to pull the small suction cup upwards, insert the spudger in the small opening.
Pry the front panel downwards with the spudger while continuing to pull the small suction cup upwards.
17 farklı kişi bu kılavuzu tamamladı.
11 Yorum
please help me how to solder the flex cable to the motherboard
how much this board..???
