Ana içeriğe geç
Sony Xperia Z1 Compact - Display Assembly Replacement Replacement
Neye ihtiyacın var
Videoya Genel Bakış
  1. Sony Xperia Z1 Compact - Display Assembly Replacement Replacement, Display Assembly Replacement: adım 1, 2 resimden 1. Sony Xperia Z1 Compact - Display Assembly Replacement Replacement, Display Assembly Replacement: adım 1, 2 resimden 2.
    • Xperia Z1 Compact with a broken screen.
    • Replacement Display assembly and Adhesive stickers.
  2. Sony Xperia Z1 Compact - Display Assembly Replacement Replacement: adım 2, 3 resimden 1. Sony Xperia Z1 Compact - Display Assembly Replacement Replacement: adım 2, 3 resimden 2. Sony Xperia Z1 Compact - Display Assembly Replacement Replacement: adım 2, 3 resimden 3.
    • Use hair dryer or heat gun and warm the glass for ~1 minute.
    • Start the separating from the earpiece hole. Use a thin plastic tool (plastic pick).
  3. Sony Xperia Z1 Compact - Display Assembly Replacement Replacement: adım 3, 3 resimden 1. Sony Xperia Z1 Compact - Display Assembly Replacement Replacement: adım 3, 3 resimden 2. Sony Xperia Z1 Compact - Display Assembly Replacement Replacement: adım 3, 3 resimden 3.
    • Disconnect the display assemble flex cable.
    Don't do what I did and try to separate the display with the plastic frame - until I realized my mistake. I broke the glue line which makes the phone water proof to some extent, but tried to re-glue the frame by using the heat gun.
    gerhardbarkhorn - Yanıt
  4. Sony Xperia Z1 Compact - Display Assembly Replacement Replacement: adım 4, 3 resimden 1. Sony Xperia Z1 Compact - Display Assembly Replacement Replacement: adım 4, 3 resimden 2. Sony Xperia Z1 Compact - Display Assembly Replacement Replacement: adım 4, 3 resimden 3.
    • Clean the frame from the adhesive tape.
    • Connect the new spare part for test.
    hi i've already do this job one time, but i can't clean the old glue properly, and i have to do everything one more time. could you suggest me something to remove the old adhesive from the frame?
    BI- -BBI - Yanıt
  5. Sony Xperia Z1 Compact - Display Assembly Replacement Replacement: adım 5, 2 resimden 1. Sony Xperia Z1 Compact - Display Assembly Replacement Replacement: adım 5, 2 resimden 2.
    • Disconnect the display and install the adhesive sticker.
  6. Sony Xperia Z1 Compact - Display Assembly Replacement Replacement: adım 6, 3 resimden 1. Sony Xperia Z1 Compact - Display Assembly Replacement Replacement: adım 6, 3 resimden 2. Sony Xperia Z1 Compact - Display Assembly Replacement Replacement: adım 6, 3 resimden 3.
    • Now we a ready to install the new display.
    In this step, I noticed a small difference between original screen and replacement screen. The original screen had a smal, oddly shaped, transparent plastic piece on the back of the display cable. The replacement display had not. On the second picture of step 1 in this tutorial, you can see that the replacement display shown here does not have this either.
    I figured, it might help, keep the cable firmly attached to the phone, since it fills up the space, into which the cable could bend.
    It was really easy to peel of from the original cable with the Spudger. The adhesive was not too strong and the bonding surface was really smal, too. But I had to be carefull with the tiny electronic pieces on the cable. I think, the odd shape is because of the small area and those tiny pieces.
    On my replacement display, the plastic piece fitted well and since it was still sticky, I just placed it there. You have to be super careful, not to damage those tiny electronic pieces and try not to put the plastic piece on top of one.
    Niklas Möller - Yanıt
  7. Sony Xperia Z1 Compact - Display Assembly Replacement Replacement: adım 7, 1 resimden 1.
    • That's all!
Sonuç
16 farklı kişi bu kılavuzu tamamladı.
ZFix
191.182 İtibar
330 adet Kılavuz yazıldı
Ekip
Master Techs Master Techs üyesi
Community
322 Üyeler
2.521 adet Kılavuz yazıldı
5 Yorum
Beware! There’s no mention of removing the battery door and taking out the 4 screws that hold the screen assembly in place. If you don’t do that and then pry to hard when trying to remove the screen I’m pretty sure you’ll end up breaking something ;)
Krister Turøy - Yanıt
Krister Turoy, I think you are wrong. I just removed the screen and there were no screws. Be careful not to mix um Z1 compact and XZ1 compact or something else.
Niklas Möller -
There has a tips to remove screen directly and won’t break.
Let’s open the lower part first (that less of the sticker and it close to the edge). Heat can help here. (Do it carefully, if still feel hard to open it, try heat up again, don’t use just force).
When you success open lower part. Open it a little to see space that you can see through from right side of the phone to the left side.
Use needle and yarn. Send it through that space (becarefull it should be a space between pair cable and back of the screen). Now we have a yarn line that we will use to cut the glue until finish up to upper part of the screen. Still need a heat in process. But more safer and it won’t break your screen :)
Sompol Investment Story - Yanıt
Again. Needle and yarn method must send in a space between pair cable and back the of screen. NOT a space between pair cable and phone body. Because we will use it to cut sticker glue from near bottom-middle part to a top part of the screen and we don’t want it the cut the pair cable.
There had another risk in replace a screen.
If the new screen have defect in their circuit. When you put it to the phone, it will destroy an displaying interface of the phone.
If it happen, the phone it done for, replace a new screen couldn’t help anymore. It’s will always black. No backlight shining.
The phone still work if you see the notification LED and sound. But without screen. It’s done for. (You could call it half death).
I just experience it myself yesterday. The new screen kill my phone in that way. Now I’m looking for a way to fix, but still cannot find any hope.
Replace mother board could help but It would like buying a new phone (don’t forget that still need to find a new screen that not kill you phone again). If that so I will choose my phone to RIP instead. Sad but I must overcome this.
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 7
Her zaman: 11,131
