Ana içeriğe geç
Sony Xperia Z1 Compact Battery Replacement
Neye ihtiyacın var
  1. Sony Xperia Z1 Compact Battery Replacement, Back Cover: adım 1, 1 resimden 1.
    • Heat along the edges of the back cover using a heat gun to soften the glue.
  2. Sony Xperia Z1 Compact Battery Replacement: adım 2, 1 resimden 1.
    • Attach the small suction cup to the back cover near the bottom of the phone.
    • Pull up on the suction cup and insert the plastic opening tool in between the back cover and the rest of the phone.
  3. Sony Xperia Z1 Compact Battery Replacement: adım 3, 2 resimden 1. Sony Xperia Z1 Compact Battery Replacement: adım 3, 2 resimden 2.
    • Move the spudger around the edge of the back cover to separate it from the black adhesive.
    • Separating the back cover from the rest of the phone ruins the adhesive which makes it no longer waterproof.
  4. Sony Xperia Z1 Compact Battery Replacement, Battery: adım 4, 2 resimden 1. Sony Xperia Z1 Compact Battery Replacement, Battery: adım 4, 2 resimden 2.
    • Carefully disconnect the battery from the logic board by using the plastic spudger as a lever.
  5. Sony Xperia Z1 Compact Battery Replacement: adım 5, 2 resimden 1. Sony Xperia Z1 Compact Battery Replacement: adım 5, 2 resimden 2.
    • Remove the single 1 x 3.0 mm screw holding the battery in using the JIS #00 screwdriver.
    The replacement batteries probably come without the new NFC sticker, so you’ll have to transfer it from the original one to the replacement. This can be easily done with an iPlastix and a good amount of isopropyl alcohol. Do this carefully.
    Stefano Restuccia - Yanıt
  6. Sony Xperia Z1 Compact Battery Replacement: adım 6, 1 resimden 1.
    • Pry the battery up from the ends using the plastic spudger until the battery pops out of the enclosure.
  7. Sony Xperia Z1 Compact Battery Replacement: adım 7, 1 resimden 1.
    • Remove the battery from the device
Sonuç
12 farklı kişi bu kılavuzu tamamladı.
kinan badr
386 İtibar
1 Kılavuz yazıldı
Ekip
3 Yorum
is there any reliable source for good replacement battery purchase?
Upendra Gandhi - Yanıt
What is the Ariel stuck on the battery ?
Tony - Yanıt
NFC Antenna. You should carefully transplant it to new battery, in case your new battery is without one (what is the case for most 3rd party batteries available)
Peter Pepo -
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 27
Her zaman: 11,466
