Bu kılavuzda güncel değişiklikler var. En son onaylanmamış sürüme geçin.
Giriş
This guide will show you how to replace the earpiece speaker that no longer works.
Neye ihtiyacın var
Heat along the edges of the back cover using a heat gun to soften the glue.
Carefully disconnect the battery from the logic board by using the plastic spudger as a lever.
Unscrew the four screws on the corners of the back frame using the JIS #00 screwdriver.
Remove the square rubber gasket from the camera using the plastic spudger.
Bir başkası bu kılavuzu tamamladı.
