Giriş
Use this guide to replace the front-facing camera in your Sony Xperia Z3 Compact.
Neye ihtiyacın var
Carefully use a heat gun or hairdryer to melt the adhesive holding the rear case to the phone.
Use a suction cup to lift the rear case slightly, enough to slide an opening pick around the edge and loosen the adhesive.
Remove back cover.
3 farklı kişi bu kılavuzu tamamladı.
