Ana içeriğe geç
Sony Xperia Z3 Dual Battery Replacement
Neye ihtiyacın var
Videoya Genel Bakış
  1. Sony Xperia Z3 Dual Battery Replacement, Battery: adım 1, 2 resimden 1. Sony Xperia Z3 Dual Battery Replacement, Battery: adım 1, 2 resimden 2.
    • Heat the back cover to soften the adhesive sticker.
    • Use the suction cup to open a gap from top side or bottom side.
  2. Sony Xperia Z3 Dual Battery Replacement: adım 2, 3 resimden 1. Sony Xperia Z3 Dual Battery Replacement: adım 2, 3 resimden 2. Sony Xperia Z3 Dual Battery Replacement: adım 2, 3 resimden 3.
    • Insert into the guitar pick and slide to cut the sticker.
    • Remove the back cover.
    In step 5 where it says that there is adhesive on the battery, my adhesive was actually joining the battery to the back plate making this step quite difficult. I had to focus the heat on the backplate right where the battery was and then use a long lever to separate the battery from the back plate.
    Seb Carroll - Yanıt
  3. Sony Xperia Z3 Dual Battery Replacement: adım 3, 1 resimden 1.
    • Release battery flex connector carefully to avoid breaking the pins.
  4. Sony Xperia Z3 Dual Battery Replacement: adım 4, 1 resimden 1.
    • Get free that sticker which for fastening the battery.
  5. Sony Xperia Z3 Dual Battery Replacement: adım 5, 1 resimden 1.
    • Pry up with a little effort because there is adhesive under the battery though not so strong.
  6. Sony Xperia Z3 Dual Battery Replacement: adım 6, 1 resimden 1.
    • That's Sony Xperia Z3 Dual 3100mAh battery.
    • When you finished to replace battery and ready to assemble the phone, you need a piece of new back cover adhesive sticker because it's disposable and the old one can't use any more.
Sonuç
12 farklı kişi bu kılavuzu tamamladı.
Sophia
43.810 İtibar
62 adet Kılavuz yazıldı
2 Yorum
Do you happen to know if the Z3 battery will also fit the Z3v i cant seem to find a replacement specifically for the Z3v
Victor Aguirre - Yanıt
Just finished this guide thank you!
Seb Carroll - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 15
Her zaman: 28,202
