Giriş
This is the replacement guide for Sony Xperia Z3 Dual as well as Sony Xperia Z3 front camera.
  1. Power off the phone and remove two SIM card trays before replacement.
    • Power off the phone and remove two SIM card trays before replacement.
  2. Heat to soften back cover adhesive sticker. Use suction cup to open a gap and insert into the guitar pick. Slide the guitar pick to cut the sticker. Use suction cup to open a gap and insert into the guitar pick. Slide the guitar pick to cut the sticker.
    • Heat to soften back cover adhesive sticker.
    • Use suction cup to open a gap and insert into the guitar pick. Slide the guitar pick to cut the sticker.
  3. Remove back cover carefully and avoid cracking the glass.
    • Remove back cover carefully and avoid cracking the glass.
  4. Pro Tech Toolkit içeren veya $100,00tüm siparişlerde ücretsiz kargo!
    Mağazamıza Göz Atın
  5. Remove battery or not is optional. Remove it makes the replacement convenient while keep it also will not block the replacement. Remove battery or not is optional. Remove it makes the replacement convenient while keep it also will not block the replacement. Remove battery or not is optional. Remove it makes the replacement convenient while keep it also will not block the replacement.
    • Remove battery or not is optional. Remove it makes the replacement convenient while keep it also will not block the replacement.
  6. Remove screws at first.
    • Remove screws at first.
  7. Remove three pieces of securing bracket. Remove three pieces of securing bracket. Remove three pieces of securing bracket.
    • Remove three pieces of securing bracket.
  8. Release all the connectors connecting with motherboard. Pry the motherboard up from left side and remove it. The motherboard is hold tightly by some hidden keys, so you should be very careful. Pry the motherboard up from left side and remove it. The motherboard is hold tightly by some hidden keys, so you should be very careful.
    • Release all the connectors connecting with motherboard.
    • Pry the motherboard up from left side and remove it. The motherboard is hold tightly by some hidden keys, so you should be very careful.
  9. Release the connector and pull out the flex at first, please be careful as you can. Remove the front camera finally.
    • Release the connector and pull out the flex at first, please be careful as you can.
    • Remove the front camera finally.
Sonuç
2 başka kişi bu kılavuzu tamamladı.
Sophia
41.395 İtibar
62 adet Kılavuz yazıldı
0 Yorum
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 0
Son 30 Gün: 7
Her zaman: 2,126
