Ana içeriğe geç
Eşyalarını Tamir Et
Onarma Hakkı
Mağaza
  1. Heat to soften back cover sticker. Place suction cup and pull open a gap.
    • Heat to soften back cover sticker.
    • Place suction cup and pull open a gap.
  2. Insert into guitar pick, slide and cut the sticker. Finally, remove the back cover. Insert into guitar pick, slide and cut the sticker. Finally, remove the back cover. Insert into guitar pick, slide and cut the sticker. Finally, remove the back cover.
    • Insert into guitar pick, slide and cut the sticker. Finally, remove the back cover.
  3. Remove the battery. Remove the battery. Remove the battery.
    • Remove the battery.
  4. TÜM SEKMELERİ AÇ
    Mac için RAM Yükseltme Kit'leri
    Kit Satın Al
    Tüm Sekmeler İçin Yeterli RAM
    Kit Satın Al
  5. Twist off two screws here. Release all the connectors connecting with loudspeaker assembly. Remove vibrator securing bracket.
    • Twist off two screws here.
    • Release all the connectors connecting with loudspeaker assembly.
    • Remove vibrator securing bracket.
  6. Remove loudspeaker assembly cover and assembly itself. Remove loudspeaker assembly cover and assembly itself.
    • Remove loudspeaker assembly cover and assembly itself.
  7. Pry up the MIC. It's a part of the main flex. Release the connector with LCD screen flex and the connector with motherboard. Release the connector with LCD screen flex and the connector with motherboard.
    • Pry up the MIC. It's a part of the main flex.
    • Release the connector with LCD screen flex and the connector with motherboard.
  8. Push the upper power button & volume button flex branch bracket as the direction marked, and then remove it easily. Pry up the lower shutter button flex branch bracket carefully. It's different from the upper one, it's come with the flex together but the upper one not. Pry up the lower shutter button flex branch bracket carefully. It's different from the upper one, it's come with the flex together but the upper one not.
    • Push the upper power button & volume button flex branch bracket as the direction marked, and then remove it easily.
    • Pry up the lower shutter button flex branch bracket carefully. It's different from the upper one, it's come with the flex together but the upper one not.
  9. Get the flex from the sticker underneath carefully. And then, take the power button & volume button flex branch out from the slot. Finally, remove the whole main flex.
    • Get the flex from the sticker underneath carefully.
    • And then, take the power button & volume button flex branch out from the slot.
    • Finally, remove the whole main flex.
Sonuç
14 farklı kişi bu kılavuzu tamamladı.
Sophia
42.946 İtibar
62 adet Kılavuz yazıldı
3 Yorum
Hello
I changed my power, but I felt the power button action do you think the problem of what can be
Thanks
mehdi ghanbarian - Yanıt
very good thnx
gamaa19700 - Yanıt
Is it ok to remove the small copper stickers under the flex?
Miguel Damayo - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 15
Son 30 gün: 75
Her zaman: 8,286
