Ana içeriğe geç
Sony Xperia Z5 Battery Replacement
Arşivlenmiş Kılavuz
Bu kılavuz sadece arşivsel amaçlarla muhafaza edilmiştir. Onarımınızı gerçekleştirmek için kılavuzun güncel halini kullanın.
Neye ihtiyacın var
  1. Sony Xperia Z5 Battery Replacement, Battery: adım 1, 2 resimden 1. Sony Xperia Z5 Battery Replacement, Battery: adım 1, 2 resimden 2.
    • Remove SIM card tray.
  2. Sony Xperia Z5 Battery Replacement: adım 2, 2 resimden 1. Sony Xperia Z5 Battery Replacement: adım 2, 2 resimden 2.
    • Heat the back cover to soften the adhesive.
    • Place the suction cup and insert metal opening tool to open a gap from top side.
    Any recommendation on how hot and how long to heat it up?
    Benedikt M. - Yanıt
  3. Sony Xperia Z5 Battery Replacement: adım 3, 3 resimden 1. Sony Xperia Z5 Battery Replacement: adım 3, 3 resimden 2. Sony Xperia Z5 Battery Replacement: adım 3, 3 resimden 3.
    • Insert the guitar picks and slide it to cut the adhesive underneath.
    • Remove back cover.
    Does the adhesive in this step need to be replaced? Don't really want to lose the water proofing…
    Harald McArthur - Yanıt
    Usually the adhesive is slightly damaged during the opening procedure which might void the water resistance of the phone. So to re-seal the back cover it’s best to use fresh adhesive. If you don’t find a pre-cut adhesive tailored to the Z5 you can go with double-sided adhesive tape or an adhesive glue. If you find the remaining adhesive in good condition and trust it to do its job, the re-use it by heating it up a little bit and applying pressure to the re-attached back cover for a few hours.
    Tobias Isakeit -
  4. Sony Xperia Z5 Battery Replacement: adım 4, 3 resimden 1. Sony Xperia Z5 Battery Replacement: adım 4, 3 resimden 2. Sony Xperia Z5 Battery Replacement: adım 4, 3 resimden 3.
    • Release battery connector and pull off the adhesive tape underneath.
    • Pry up battery.
    Can you tell me the wire connection colour code of battery? because i brought the ones but its not working.
    denkim2701 - Yanıt
Bitiş Çizgisi
25 farklı kişi bu kılavuzu tamamladı.
Lenka
2.376 İtibar
6 adet Kılavuz yazıldı
7 Yorum
I missed the part about the adhesive for the battery and broke the tabs off. Made it slightly harder but I got it. Thanks for the instructions. Now I can get all my things off of it
Braydon - Yanıt
can you put a link to where i could buy the battery from? it would be helpful, thank you
ido r - Yanıt
worked a treat - simple straightforward - thanks!!
John Turnbull - Yanıt
umm how do you put the cover back on?
Dulantha Fernando - Yanıt
Just push and then consolidate with heat, I used hair dryer.
Jorge García Laosa -
can reuse the same cover, or need a new unit ?
Chu Tat Liang -
Will this work for z5 premium ???
Q8Lucifer - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 2
Her zaman: 52,870
