Ana içeriğe geç
Sony Xperia Z5 Charging Port Flex Replacement
Neye ihtiyacın var
  1. Sony Xperia Z5 Charging Port Flex Replacement, Charging Port Flex: adım 1, 2 resimden 1. Sony Xperia Z5 Charging Port Flex Replacement, Charging Port Flex: adım 1, 2 resimden 2.
    • Remove SIM card tray.
  2. Sony Xperia Z5 Charging Port Flex Replacement: adım 2, 2 resimden 1. Sony Xperia Z5 Charging Port Flex Replacement: adım 2, 2 resimden 2.
    • Heat the back cover to soften the adhesive sticker.
    • Place the suction cup and inert metal opening tool to open a gap from top side.
  3. Sony Xperia Z5 Charging Port Flex Replacement: adım 3, 3 resimden 1. Sony Xperia Z5 Charging Port Flex Replacement: adım 3, 3 resimden 2. Sony Xperia Z5 Charging Port Flex Replacement: adım 3, 3 resimden 3.
    • Insert the guitar pick and slide it to cut the adhesive sticker underneath.
    • Remove back cover.
  4. Sony Xperia Z5 Charging Port Flex Replacement: adım 4, 3 resimden 1. Sony Xperia Z5 Charging Port Flex Replacement: adım 4, 3 resimden 2. Sony Xperia Z5 Charging Port Flex Replacement: adım 4, 3 resimden 3.
    • Release battery connector and pull off the adhesive tape underneath.
    • Pry up battery.
  5. Sony Xperia Z5 Charging Port Flex Replacement: adım 5, 3 resimden 1. Sony Xperia Z5 Charging Port Flex Replacement: adım 5, 3 resimden 2. Sony Xperia Z5 Charging Port Flex Replacement: adım 5, 3 resimden 3.
    • Release rear camera connector, front camera connector, audio jack flex connector and main flex connector on the motherboard and remove the screws there.
    • Take away the plastic bracket.
  6. Sony Xperia Z5 Charging Port Flex Replacement: adım 6, 3 resimden 1. Sony Xperia Z5 Charging Port Flex Replacement: adım 6, 3 resimden 2. Sony Xperia Z5 Charging Port Flex Replacement: adım 6, 3 resimden 3.
    • Remove metal cover securing loudspeaker and twist off screws.
    • Pry up and loosen the bottom side of main flex assembly.
  7. Sony Xperia Z5 Charging Port Flex Replacement: adım 7, 2 resimden 1. Sony Xperia Z5 Charging Port Flex Replacement: adım 7, 2 resimden 2.
    • Remove main flex. ( Attention: the fingerprint sensor connector is here, be careful to loosen it)
  8. Sony Xperia Z5 Charging Port Flex Replacement: adım 8, 2 resimden 1. Sony Xperia Z5 Charging Port Flex Replacement: adım 8, 2 resimden 2.
    • This is main flex assembly. (It comes with loudspeaker and vibration motor )
  9. Sony Xperia Z5 Charging Port Flex Replacement: adım 9, 2 resimden 1. Sony Xperia Z5 Charging Port Flex Replacement: adım 9, 2 resimden 2.
    • Remove rear camera.
  10. Sony Xperia Z5 Charging Port Flex Replacement: adım 10, 3 resimden 1. Sony Xperia Z5 Charging Port Flex Replacement: adım 10, 3 resimden 2. Sony Xperia Z5 Charging Port Flex Replacement: adım 10, 3 resimden 3.
    • Remove that securing bracket, then remove front camera.
  11. Sony Xperia Z5 Charging Port Flex Replacement: adım 11, 3 resimden 1. Sony Xperia Z5 Charging Port Flex Replacement: adım 11, 3 resimden 2. Sony Xperia Z5 Charging Port Flex Replacement: adım 11, 3 resimden 3.
    • Release connectors on the motherboard. Remove motherboard.
  12. Sony Xperia Z5 Charging Port Flex Replacement: adım 12, 3 resimden 1. Sony Xperia Z5 Charging Port Flex Replacement: adım 12, 3 resimden 2. Sony Xperia Z5 Charging Port Flex Replacement: adım 12, 3 resimden 3.
    • Remove charging port flex.
Sonuç
14 farklı kişi bu kılavuzu tamamladı.
Lenka
2.376 İtibar
6 adet Kılavuz yazıldı
3 Yorum
How about the waterproof adhesive ?
Tess - Yanıt
Would you have a step by step method to replace it ?
Tess - Yanıt
I can’t turn my phone back on. Any clues?
Bjoern Aeschlimann - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 39
Her zaman: 17,528
