Ana içeriğe geç
Sony Xperia Z5 Compact LCD Screen Assembly Replacement
Neye ihtiyacın var
Videoya Genel Bakış
  1. Sony Xperia Z5 Compact LCD Screen Assembly Replacement, LCD Screen Assembly: adım 1, 2 resimden 1. Sony Xperia Z5 Compact LCD Screen Assembly Replacement, LCD Screen Assembly: adım 1, 2 resimden 2.
    • Power off and remove SIM card tray.
  2. Sony Xperia Z5 Compact LCD Screen Assembly Replacement: adım 2, 3 resimden 1. Sony Xperia Z5 Compact LCD Screen Assembly Replacement: adım 2, 3 resimden 2. Sony Xperia Z5 Compact LCD Screen Assembly Replacement: adım 2, 3 resimden 3.
    • Heat up the back cover to soften the adhesive.
    • Place the suction cup to open a gap from top side, then insert guitar picks and slide it to cut the adhesive underneath.
    • Remove back cover.
  3. Sony Xperia Z5 Compact LCD Screen Assembly Replacement: adım 3, 2 resimden 1. Sony Xperia Z5 Compact LCD Screen Assembly Replacement: adım 3, 2 resimden 2.
    • Twist off 10 Phillips screws all.
    • Loosen NFC clip and flashlight clip.
  4. Sony Xperia Z5 Compact LCD Screen Assembly Replacement: adım 4, 3 resimden 1. Sony Xperia Z5 Compact LCD Screen Assembly Replacement: adım 4, 3 resimden 2. Sony Xperia Z5 Compact LCD Screen Assembly Replacement: adım 4, 3 resimden 3.
    • Remove the plastic bracket.
    • Pry up and remove back frame.
  5. Sony Xperia Z5 Compact LCD Screen Assembly Replacement: adım 5, 3 resimden 1. Sony Xperia Z5 Compact LCD Screen Assembly Replacement: adım 5, 3 resimden 2. Sony Xperia Z5 Compact LCD Screen Assembly Replacement: adım 5, 3 resimden 3.
    • Remove front camera.
  6. Sony Xperia Z5 Compact LCD Screen Assembly Replacement: adım 6, 3 resimden 1. Sony Xperia Z5 Compact LCD Screen Assembly Replacement: adım 6, 3 resimden 2. Sony Xperia Z5 Compact LCD Screen Assembly Replacement: adım 6, 3 resimden 3.
    • Remove rear camera.
  7. Sony Xperia Z5 Compact LCD Screen Assembly Replacement: adım 7, 2 resimden 1. Sony Xperia Z5 Compact LCD Screen Assembly Replacement: adım 7, 2 resimden 2.
    • Remove loudspeaker.
  8. Sony Xperia Z5 Compact LCD Screen Assembly Replacement: adım 8, 3 resimden 1. Sony Xperia Z5 Compact LCD Screen Assembly Replacement: adım 8, 3 resimden 2. Sony Xperia Z5 Compact LCD Screen Assembly Replacement: adım 8, 3 resimden 3.
    • Release charging port connector.
    • Remove plastic protective bar.
    • Pry up motherboard assembly from this side. There are three flex connectors connecting the motherboard underneath. So pry up the motherboard assembly gently.
  9. Sony Xperia Z5 Compact LCD Screen Assembly Replacement: adım 9, 3 resimden 1. Sony Xperia Z5 Compact LCD Screen Assembly Replacement: adım 9, 3 resimden 2. Sony Xperia Z5 Compact LCD Screen Assembly Replacement: adım 9, 3 resimden 3.
    • Push audio jack out of the slot, no adhesive underneath.
    • Release LCD flex connector and main flex connector by flipping up the white locking tab of the connector base.
    • Separate motherboard assembly from middle housing.
  10. Sony Xperia Z5 Compact LCD Screen Assembly Replacement: adım 10, 3 resimden 1. Sony Xperia Z5 Compact LCD Screen Assembly Replacement: adım 10, 3 resimden 2. Sony Xperia Z5 Compact LCD Screen Assembly Replacement: adım 10, 3 resimden 3.
    • The sticker underneath LCD assembly is a little bit strong, so use heat gun to soften it for a few minutes.
    • Remove LCD with digitizer assembly carefully.
  11. Sony Xperia Z5 Compact LCD Screen Assembly Replacement: adım 11, 1 resimden 1.
    • Done.
Sonuç
23 farklı kişi bu kılavuzu tamamladı.
Witrigs
69.454 İtibar
378 adet Kılavuz yazıldı
18 Yorum
But what kind of glue do we need to use when we reconnect the screen and the case?
Ronen Yudzinsky - Yanıt
screen replacement is possible without removing the back cover and logic board, similar to the Z1 compact. Simply remove the metal cover once you took the screen off to disconnect the lcd/digi cable.
Toby Liedke - Yanıt
Yeah, I'm confused as to why everything from the back needs to be taken out, when you have to heat up the front sticker anyways and disconnect it. Seems fairly simple to just heat up, cut side adhesive, lift, unplug.
Brian Santero -
Have you done the repair that way, Toby Liedke?
jesinisterra - Yanıt
nice guide, for my first reparation, all was fine. Thanks!
bvo - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 53
Her zaman: 33,522
