Ana içeriğe geç
Sony Xperia Z5 Compact Screen Replacement
Neye ihtiyacın var
  1. Sony Xperia Z5 Compact Screen Replacement, Charging port flex: adım 1, 2 resimden 1. Sony Xperia Z5 Compact Screen Replacement, Charging port flex: adım 1, 2 resimden 2.
    • Power off and remove SIM card tray.
  2. Sony Xperia Z5 Compact Screen Replacement: adım 2, 3 resimden 1. Sony Xperia Z5 Compact Screen Replacement: adım 2, 3 resimden 2. Sony Xperia Z5 Compact Screen Replacement: adım 2, 3 resimden 3.
    • Heat up the back cover to soften the adhesive.
    • Place the suction cup to open a gap from top side, then insert guitar picks and slide it to cut the adhesive underneath.
    • Remove back cover.
  3. Sony Xperia Z5 Compact Screen Replacement: adım 3, 2 resimden 1. Sony Xperia Z5 Compact Screen Replacement: adım 3, 2 resimden 2.
    • Remove all 10 Phillips screws.
    • Disconnect NFC clip and flashlight clip.
  4. Sony Xperia Z5 Compact Screen Replacement: adım 4, 3 resimden 1. Sony Xperia Z5 Compact Screen Replacement: adım 4, 3 resimden 2. Sony Xperia Z5 Compact Screen Replacement: adım 4, 3 resimden 3.
    • Remove the plastic bracket.
    • Pry up and remove back frame.
  5. Sony Xperia Z5 Compact Screen Replacement: adım 5, 3 resimden 1. Sony Xperia Z5 Compact Screen Replacement: adım 5, 3 resimden 2. Sony Xperia Z5 Compact Screen Replacement: adım 5, 3 resimden 3.
    • Remove front camera.
  6. Sony Xperia Z5 Compact Screen Replacement: adım 6, 3 resimden 1. Sony Xperia Z5 Compact Screen Replacement: adım 6, 3 resimden 2. Sony Xperia Z5 Compact Screen Replacement: adım 6, 3 resimden 3.
    • Remove rear camera.
  7. Sony Xperia Z5 Compact Screen Replacement: adım 7, 3 resimden 1. Sony Xperia Z5 Compact Screen Replacement: adım 7, 3 resimden 2. Sony Xperia Z5 Compact Screen Replacement: adım 7, 3 resimden 3.
    • Remove loudspeaker.
  8. Sony Xperia Z5 Compact Screen Replacement: adım 8, 3 resimden 1. Sony Xperia Z5 Compact Screen Replacement: adım 8, 3 resimden 2. Sony Xperia Z5 Compact Screen Replacement: adım 8, 3 resimden 3.
    • Release charging port connector.
    • Remove plastic protective bar.
    • Pry up motherboard assembly from this side. There are three flex connectors connecting the motherboard underneath. So pry up the motherboard assembly gently.
  9. Sony Xperia Z5 Compact Screen Replacement: adım 9, 1 resimden 1.
    • Remove charging port flex.
  10. Sony Xperia Z5 Compact Screen Replacement, Screen: adım 10, 2 resimden 1. Sony Xperia Z5 Compact Screen Replacement, Screen: adım 10, 2 resimden 2.
    • Remove the motherboard/battery assembly.
    • Using a spudger, release the battery connector from the motherboard.
  11. Sony Xperia Z5 Compact Screen Replacement: adım 11, 2 resimden 1. Sony Xperia Z5 Compact Screen Replacement: adım 11, 2 resimden 2.
    • Using a suction cup, create a space between the screen and the phone.
    • Using an opening tool, pry the LCD screen up.
Sonuç
Bir başkası bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 33
Her zaman: 826
