Ana içeriğe geç
Sony Xperia Z5 LCD Screen Replacement
Neye ihtiyacın var
Videoya Genel Bakış
  1. Sony Xperia Z5 LCD Screen Replacement, LCD Screen: adım 1, 2 resimden 1. Sony Xperia Z5 LCD Screen Replacement, LCD Screen: adım 1, 2 resimden 2.
    • Remove SIM card tray.
  2. Sony Xperia Z5 LCD Screen Replacement: adım 2, 2 resimden 1. Sony Xperia Z5 LCD Screen Replacement: adım 2, 2 resimden 2.
    • Heat the back cover to soften the adhesive sticker.
    • Place the suction cup and insert metal opening tool to open a gap from top side.
  3. Sony Xperia Z5 LCD Screen Replacement: adım 3, 3 resimden 1. Sony Xperia Z5 LCD Screen Replacement: adım 3, 3 resimden 2. Sony Xperia Z5 LCD Screen Replacement: adım 3, 3 resimden 3.
    • Insert the guitar pick and slide it to cut the adhesive sticker underneath.
    • Remove back cover.
  4. Sony Xperia Z5 LCD Screen Replacement: adım 4, 3 resimden 1. Sony Xperia Z5 LCD Screen Replacement: adım 4, 3 resimden 2. Sony Xperia Z5 LCD Screen Replacement: adım 4, 3 resimden 3.
    • Release battery connector.
    • Pull off the adhesive tape underneath the battery.
    • Pry up battery.
  5. Sony Xperia Z5 LCD Screen Replacement: adım 5, 3 resimden 1. Sony Xperia Z5 LCD Screen Replacement: adım 5, 3 resimden 2. Sony Xperia Z5 LCD Screen Replacement: adım 5, 3 resimden 3.
    • Release rear camera connector, front camera connector, audio jack connector and main flex connector on the motherboard.
    • Twist off screws there.
    • Remove that rubber securing bracket.
  6. Sony Xperia Z5 LCD Screen Replacement: adım 6, 3 resimden 1. Sony Xperia Z5 LCD Screen Replacement: adım 6, 3 resimden 2. Sony Xperia Z5 LCD Screen Replacement: adım 6, 3 resimden 3.
    • Remove metal cover and twist off two screws.
    • Loosen the bottom side of main flex assembly.
  7. Sony Xperia Z5 LCD Screen Replacement: adım 7, 3 resimden 1. Sony Xperia Z5 LCD Screen Replacement: adım 7, 3 resimden 2. Sony Xperia Z5 LCD Screen Replacement: adım 7, 3 resimden 3.
    • Loosen side button contactors ( Attention: the fingerprint sensor is here, be careful to loosen it), then remove the whole main flex assembly.
  8. Sony Xperia Z5 LCD Screen Replacement: adım 8, 3 resimden 1. Sony Xperia Z5 LCD Screen Replacement: adım 8, 3 resimden 2. Sony Xperia Z5 LCD Screen Replacement: adım 8, 3 resimden 3.
    • Remove rear camera.
    • Remove that securing bracket, then remove front camera.
  9. Sony Xperia Z5 LCD Screen Replacement: adım 9, 3 resimden 1. Sony Xperia Z5 LCD Screen Replacement: adım 9, 3 resimden 2. Sony Xperia Z5 LCD Screen Replacement: adım 9, 3 resimden 3.
    • Release LCD screen flex connector, charging port connector, microphone connector here.
    • Remove motherboard.
  10. Sony Xperia Z5 LCD Screen Replacement: adım 10, 2 resimden 1. Sony Xperia Z5 LCD Screen Replacement: adım 10, 2 resimden 2.
    • Remove charging port flex.
  11. Sony Xperia Z5 LCD Screen Replacement: adım 11, 2 resimden 1. Sony Xperia Z5 LCD Screen Replacement: adım 11, 2 resimden 2.
    • Remove microphone.
  12. Sony Xperia Z5 LCD Screen Replacement: adım 12, 2 resimden 1. Sony Xperia Z5 LCD Screen Replacement: adım 12, 2 resimden 2.
    • Remove the metal bracket covering on the LCD screen flex.
  13. Sony Xperia Z5 LCD Screen Replacement: adım 13, 3 resimden 1. Sony Xperia Z5 LCD Screen Replacement: adım 13, 3 resimden 2. Sony Xperia Z5 LCD Screen Replacement: adım 13, 3 resimden 3.
    • The sticker underneath is strong, so use heat gun to soften it for a few minutes.
    • Remove LCD screen carefully.
    • Take extra care when prying along the bottom edge of the display to avoid damaging the display cable.
  14. Sony Xperia Z5 LCD Screen Replacement: adım 14, 1 resimden 1.
    • Done.
Sonuç
47 farklı kişi bu kılavuzu tamamladı.
Lenka
2.408 İtibar
6 adet Kılavuz yazıldı
45Kılavuz Yorumları
Awesome guide. Helped me alot. However i got blank screen after installing the new screen. Dont panic. You must replace the tape that covers the lcd filters. If you dont the metal plate will bridge the connections and the LCD will not display. I thought i broke the LCD however just replaced the tape off the original LCD and BOOM!
Kiwi phone repairs - Yanıt
What are the filters? I have a repair shop and all screens are like these. Can't find them anywhere.
Johnny -
Hi, you need to reuse the black tape sticked on the original flex cable to cover the filters on the replacement part.
Adrien Ould Madi -
I would like also to know which tape you replaced.
Patrick -
What r the lcd filters as I have replaced a screen on Sony z5 on 2 phones now and the backlight isn't working on both phones but u can see that the screens r working any help would be great thanks
Barry -
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 45
Son 7 gün: 199
Son 30 gün: 831
Her zaman: 99,968
