Giriş
Use this guide to remove the rear glass of the Sony Xperia Z5.
Opening the Sony Xperia Z5 will damage the waterproof seals on the device. If you do not replace the adhesive seals, your phone will function normally but will lose its water protection.
You’ll need replacement adhesive to reattach components when reassembling the device.
Parçalar
Before you begin, switch off your phone.
Apply a heated iOpener to the edges on the back of the phone to loosen the adhesive beneath the rear glass. Apply the iOpener for at least two minutes.
Secure the new back cover with pre-cut adhesive or double-sided adhesive tape after cleaning the according areas with isopropyl alcohol (>90%).
