Ana içeriğe geç
Sony Xperia go Front Glass/Digitizer Replacement
Neye ihtiyacın var
  1. Sony Xperia go Front Glass/Digitizer Replacement, Front Glass/Digitizer: adım 1, 1 resimden 1.
    • Show here is a Sony xperia go with broken glass digitizer.
  2. Sony Xperia go Front Glass/Digitizer Replacement: adım 2, 3 resimden 1. Sony Xperia go Front Glass/Digitizer Replacement: adım 2, 3 resimden 2. Sony Xperia go Front Glass/Digitizer Replacement: adım 2, 3 resimden 3.
    • Remove backcover, and remove all screws.
    • 1 Torx screw
    • 7 star screws (don't know their name)
    • Note some of the screws have rubber spacers, use caution to avoid breaking them. (See second Picture in this step)
    • Remove sim card tray. (See third picture)
  3. Sony Xperia go Front Glass/Digitizer Replacement: adım 3, 3 resimden 1. Sony Xperia go Front Glass/Digitizer Replacement: adım 3, 3 resimden 2. Sony Xperia go Front Glass/Digitizer Replacement: adım 3, 3 resimden 3.
    • Now the front can be seperated from the back.
    • CAUTION! there are some doublesided tape blocks situated on top of the connectors to the digitizer.
    • Use spudger to seperate these carefully from eachother.
    • Now you can open the phone sideways. Once opened, please disconnect the battery, marked on third Picture with a yellow circle.
    • Now you can disconnect digitizer cable and screen cable, marked with red circles on third picture.
    • Now you will be able to remove the front from the back of the phone.
  4. Sony Xperia go Front Glass/Digitizer Replacement: adım 4, 2 resimden 1. Sony Xperia go Front Glass/Digitizer Replacement: adım 4, 2 resimden 2.
    • Using a heat gun, heat around the edges and seperate the glass from the front cover. Work from bottom up.
    • Note the digitizer cable runs through a small hole behind the lcd, in the top of the phone.
    • When the glass is seperated, carefully lift the lcd a bit, to get the digitizer cable through the hole.
    • To protect the lcd from residue and fingerprints, cover it with masking tape, until you are ready to seal the glass to the cover.
    • When you have prepared new adhesive tape and the digitizer cable has been pulled through the hole to the backside of the phone.
    • Remove the masking tape from the lcd, and using some canned air, blow away dust and close the glass cover.
    • Finally reverse the disassembly and enjoy.
Sonuç
22 farklı kişi bu kılavuzu tamamladı.
lassedollerup
620 İtibar
1 Kılavuz yazıldı
10 Yorum
can u make guide for installing loudspeaker please
anep tg - Yanıt
Nice guide but, I only want to change front cover and back cover, because it´s damaged . If Open my xperia go, I will lost water proof and dust proof?
Juliano - Yanıt
Hello sorry for my late reply.
I haven't had the chance to replace the loudspeaker, but earpiece is a square block, that you can pry out and replace, after you have seperated the front from the back.
lassedollerup - Yanıt
Dissasembly will most likely break waterproof. Haven't tested.
Nice guide and easy to follow. Thank you.
alex jesty - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 3
Her zaman: 40,097
