Ana içeriğe geç
Sony Xplod CDX-MP30 CD Drive Motherboard Replacement
Neye ihtiyacın var
  1. Sony Xplod CDX-MP30 CD Drive Motherboard Replacement, Front Panel: adım 1, 3 resimden 1. Sony Xplod CDX-MP30 CD Drive Motherboard Replacement, Front Panel: adım 1, 3 resimden 2. Sony Xplod CDX-MP30 CD Drive Motherboard Replacement, Front Panel: adım 1, 3 resimden 3.
    • Press down the release button on the bottom left corner of the face plate.
    • Then remove the face plate carefully.
  2. Sony Xplod CDX-MP30 CD Drive Motherboard Replacement, Main Panels: adım 2, 2 resimden 1. Sony Xplod CDX-MP30 CD Drive Motherboard Replacement, Main Panels: adım 2, 2 resimden 2.
    Bu adımda kullanılan alet:
    Phillips #0 Screwdriver
    $5.49
    Satın Al
  3. Sony Xplod CDX-MP30 CD Drive Motherboard Replacement: adım 3, 3 resimden 1. Sony Xplod CDX-MP30 CD Drive Motherboard Replacement: adım 3, 3 resimden 2. Sony Xplod CDX-MP30 CD Drive Motherboard Replacement: adım 3, 3 resimden 3.
    Phillips #1 Screwdriver
    $5.49
    Satın Al
    • Using the Phillips #1 Screwdriver, unscrew the 2 thick screws (length - 7.69mm) located on both sides of the stereo.
    • Remove side-metal plates gently.
    • Use the Heavy-duty Spudger, insert the flat end under each of the black flaps indicated in the picture. Use leverage to pry and pop them loose.
  4. Sony Xplod CDX-MP30 CD Drive Motherboard Replacement: adım 4, 1 resimden 1.
    • Remove the black front plate of the stereo.
  5. Sony Xplod CDX-MP30 CD Drive Motherboard Replacement: adım 5, 2 resimden 1. Sony Xplod CDX-MP30 CD Drive Motherboard Replacement: adım 5, 2 resimden 2.
    $5.49
    Satın Al
    • Using the Phillips #0 Screwdriver, unscrew the 1 gold screw (height - 7.47mm) on the top of the stereo.
    • Lift off the top plate.
  6. Sony Xplod CDX-MP30 CD Drive Motherboard Replacement: adım 6, 3 resimden 1. Sony Xplod CDX-MP30 CD Drive Motherboard Replacement: adım 6, 3 resimden 2. Sony Xplod CDX-MP30 CD Drive Motherboard Replacement: adım 6, 3 resimden 3.
    $5.49
    Satın Al
    • Using the Phillips #0 Screwdriver, unscrew the 8 gold screws (length - 9.26mm), located on the back side of the stereo.
    • Using the Phillips #0 Screwdriver, unscrew the 2 black screws (length - 13.27mm), also located on the back of the stereo.
    • Using the Phillips #0 Screwdriver, unscrew the 1 gold screw (length - 9.3mm), located on the bottom of a hole as noted in pictures (2) and (3).
  7. Sony Xplod CDX-MP30 CD Drive Motherboard Replacement: adım 7, 3 resimden 1. Sony Xplod CDX-MP30 CD Drive Motherboard Replacement: adım 7, 3 resimden 2. Sony Xplod CDX-MP30 CD Drive Motherboard Replacement: adım 7, 3 resimden 3.
    • Carefully pull the fuse out of the back of the stereo.
  8. Sony Xplod CDX-MP30 CD Drive Motherboard Replacement: adım 8, 2 resimden 1. Sony Xplod CDX-MP30 CD Drive Motherboard Replacement: adım 8, 2 resimden 2.
    • Firmly grip the body of the stereo and pull off the silver back plate.
  9. Sony Xplod CDX-MP30 CD Drive Motherboard Replacement: adım 9, 1 resimden 1.
    $5.49
    Satın Al
  10. Sony Xplod CDX-MP30 CD Drive Motherboard Replacement: adım 10, 2 resimden 1. Sony Xplod CDX-MP30 CD Drive Motherboard Replacement: adım 10, 2 resimden 2.
    $5.49
    Satın Al
    • Using the Phillips #0 Screwdriver, unscrew the 2 gold screws (length - 7.34mm) found on both sides of the stereo.
  11. Sony Xplod CDX-MP30 CD Drive Motherboard Replacement: adım 11, 3 resimden 1. Sony Xplod CDX-MP30 CD Drive Motherboard Replacement: adım 11, 3 resimden 2. Sony Xplod CDX-MP30 CD Drive Motherboard Replacement: adım 11, 3 resimden 3.
    • Grip the top portion of the stereo, where the CD-Drive is located, and gently pull up to release it, but you will not be able to lift it all the way out.
    • Grab the two tabs located near the back of the stereo, and gently pull the CD-drive front the rest of the device.
  12. Sony Xplod CDX-MP30 CD Drive Motherboard Replacement, CD Drive Motherboard: adım 12, 1 resimden 1.
    • The CD Drive Motherboard is located on the under-side of the CD Drive itself.
    • Please refer to the iFixit soldering guide to remove the CD Drive Motherboard.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Daniel Johnson
87 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 5-35, Amido Fall 2011 Cal Poly, Team 5-35, Amido Fall 2011 üyesi
CPSU-AMIDO-F11S5G35
4 Üyeler
8 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 5
Her zaman: 3,219
