Ana içeriğe geç
Sony Xplod CDX-MP30 Front Screen Motherboard Replacement
Neye ihtiyacın var
  1. Sony Xplod CDX-MP30 Front Screen Motherboard Replacement, Front Panel: adım 1, 3 resimden 1. Sony Xplod CDX-MP30 Front Screen Motherboard Replacement, Front Panel: adım 1, 3 resimden 2. Sony Xplod CDX-MP30 Front Screen Motherboard Replacement, Front Panel: adım 1, 3 resimden 3.
    • Press down the release button on the bottom left corner of the face plate.
    • Then remove the face plate carefully.
  2. Sony Xplod CDX-MP30 Front Screen Motherboard Replacement, Front Screen Motherboard: adım 2, 1 resimden 1.
    Bu adımda kullanılan alet:
    Phillips #0 Screwdriver
    $5.49
    Satın Al
  3. Sony Xplod CDX-MP30 Front Screen Motherboard Replacement: adım 3, 3 resimden 1. Sony Xplod CDX-MP30 Front Screen Motherboard Replacement: adım 3, 3 resimden 2. Sony Xplod CDX-MP30 Front Screen Motherboard Replacement: adım 3, 3 resimden 3.
    • Use two fingers to create a small gap in the top of the faceplate, as indicated in the picture.
  4. Sony Xplod CDX-MP30 Front Screen Motherboard Replacement: adım 4, 3 resimden 1. Sony Xplod CDX-MP30 Front Screen Motherboard Replacement: adım 4, 3 resimden 2. Sony Xplod CDX-MP30 Front Screen Motherboard Replacement: adım 4, 3 resimden 3.
    Heavy-Duty Spudger
    Satın Al
    • Insert the flat end of the Heavy-duty Spudger into the opening you created.
    • Slide it to the right carefully, until you feel the screen pop off.
    • Make sure you keep the face of the screen pointed down as you carefully lift off the freed black portion of the screen - as shown in the picture.
  5. Sony Xplod CDX-MP30 Front Screen Motherboard Replacement: adım 5, 2 resimden 1. Sony Xplod CDX-MP30 Front Screen Motherboard Replacement: adım 5, 2 resimden 2.
    • Gently grab the Front Motherboard - as indicated in the picture - and lift it from the rest of the screen.
  6. Sony Xplod CDX-MP30 Front Screen Motherboard Replacement: adım 6, 1 resimden 1.
    • To remove the LCD, please refer to the iFixit soldering guide.
    • Once the LCD screen is removed, you have unrestricted access to the front screen motherboard.
Sonuç
Chao Chen
79 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 5-35, Amido Fall 2011 Cal Poly, Team 5-35, Amido Fall 2011 üyesi
CPSU-AMIDO-F11S5G35
4 Üyeler
8 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 9
Son 30 gün: 17
Her zaman: 5,612
