Giriş
Replacing the Soontrans Ergonomic Gaming Chair wheels is a fairly straightforward operation. The instructions below will direct you in a way where minimal to no error may occur during the procedure. Once the chair has been worn out due to years of aggressive movement many issues tend to occur, but the main issue that can be solved by yourself, which is replacing the wheels. With these instructions, I guarantee you'll be back to working or gaming in no time!
Neye ihtiyacın var
Flip the chair on its backside so the seat is facing upwards.
Use the 4 mm Hex key to remove the 4 hexagonal sockets attaching the hydraulic press to the seat.
Congratulations you made it!
Bir başkası bu kılavuzu tamamladı.
