Ana içeriğe geç
SoundBot SB571 Battery Replacement
Neye ihtiyacın var
    1. SoundBot SB571 Battery Replacement, Battery: adım 1, 1 resimden 1.
      • Before disassembling the speaker, make sure it is powered off.
      • Place the speaker on a flat surface.
      • Take your blue plastic opening tool and remove the outside cover.
      FixBot'a Sor
      Yorum Ekle
    2. SoundBot SB571 Battery Replacement: adım 2, 1 resimden 1.
      • Reorient the speaker so the black panel is facing up.
      • Remove the 4, 0.9 cm screws from the back panel using a Phillips PH1 screwdriver.
      • Now remove the plate.
      FixBot'a Sor
      Yorum Ekle
    3. SoundBot SB571 Battery Replacement: adım 3, 1 resimden 1.
      • Reorient the speaker so the bottom is facing up.
      • Remove the 4, 0.9cm screws from the bottom using a Phillips PH0 screw driver.
      • Now open the plate.
      FixBot'a Sor
      Yorum Ekle
    4. SoundBot SB571 Battery Replacement: adım 4, 2 resimden 1. SoundBot SB571 Battery Replacement: adım 4, 2 resimden 2.
      • With the bottom plate removed now use the blue plastic opening tool to lift up the circuit board from the device.
      FixBot'a Sor
      Yorum Ekle
    5. SoundBot SB571 Battery Replacement: adım 5, 2 resimden 1. SoundBot SB571 Battery Replacement: adım 5, 2 resimden 2.
      • Disconnect the battery wires from the circuit board.
      FixBot'a Sor
      Yorum Ekle
    6. SoundBot SB571 Battery Replacement: adım 6, 3 resimden 1. SoundBot SB571 Battery Replacement: adım 6, 3 resimden 2. SoundBot SB571 Battery Replacement: adım 6, 3 resimden 3.
      • Reorient the speaker so the back side is facing up.
      • Now that the battery wires have been disconnected, use a blue plastic tool to release the battery from the adhesive strip.
      • Loop the battery wires through the opening in the back plate.
      • The battery and it's connective wires have been completely removed from the speaker.
      FixBot'a Sor
      Yorum Ekle
Sonuç
12 farklı kişi bu kılavuzu tamamladı.
Yana
672 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 2-50, Cagle Spring 2016 USF Tampa, Team 2-50, Cagle Spring 2016 üyesi
USFT-CAGLE-S16S2G50
4 Üyeler
4 adet Kılavuz yazıldı
9Kılavuz Yorumları
Please provide the source to buy the replacement battery
Madhu Mohan Bhukya - Yanıt Paylaş
Sir ,m n jully m flipcart se soundbot buy tha jisme kuch dikat aa rhi h bettery ki bajah se
Raj Saini - Yanıt Paylaş
They don't sell batteries!!
international.loop - Yanıt Paylaş
It says above that battery not for sale.
A simple online search and you will find the battery.
Mark Friend - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 40
Her zaman: 9,611
