Ana içeriğe geç
SoundBot SB571 Speaker Grille
Neye ihtiyacın var
  1. SoundBot SB571 Speaker Grille, Speaker Grille: adım 1, 1 resimden 1.
    • Before disassembling the speaker, make sure it is powered off.
    • Place the speaker on a flat surface.
    • Take your blue plastic opening tool and remove the plastic cover.
  2. SoundBot SB571 Speaker Grille: adım 2, 3 resimden 1. SoundBot SB571 Speaker Grille: adım 2, 3 resimden 2. SoundBot SB571 Speaker Grille: adım 2, 3 resimden 3.
    • Orient the speaker so that the top is facing up.
    • Using your Phillips PH0 screwdriver unscrew the 14, 0.6cm screws from the device along the speaker grille.
  3. SoundBot SB571 Speaker Grille: adım 3, 2 resimden 1. SoundBot SB571 Speaker Grille: adım 3, 2 resimden 2.
    • Reorient the speaker so the grille is facing you.
    • Using the blue plastic opening tool, prop open the metal grille.
    • Now the speaker grille is completely removed from the device and it can be replaced.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Yana
645 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 2-50, Cagle Spring 2016 USF Tampa, Team 2-50, Cagle Spring 2016 üyesi
USFT-CAGLE-S16S2G50
4 Üyeler
Bir Yorum
Sir my soundbot sb571 one side sound doesnot work how could i do for its repairing.
Ram Meena - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 17
Her zaman: 1,638
