Ana içeriğe geç
Spark Test
Neye ihtiyacın var
  1. Spark Test, Safety precautions: adım 1, 2 resimden 1. Spark Test, Safety precautions: adım 1, 2 resimden 2.
    • Flip the power switch into the STOP position.
    • Make sure the engine is cool to the touch before proceeding.
  2. Spark Test, Remove the muffler cover: adım 2, 2 resimden 1. Spark Test, Remove the muffler cover: adım 2, 2 resimden 2.
    • Use a T27 Torx screwdriver to remove the two screws securing the bottom of the muffler cover to the motor.
  3. Spark Test: adım 3, 3 resimden 1. Spark Test: adım 3, 3 resimden 2. Spark Test: adım 3, 3 resimden 3.
    • Tilt the muffler cover up, hinging along the top edge, until it can be removed from the motor cover.
    • Remove the muffler cover.
  4. Spark Test: adım 4, 2 resimden 1. Spark Test: adım 4, 2 resimden 2.
    • Pull the spark plug boot straight off of the spark plug.
  5. Spark Test, Connect the spark tester: adım 5, 2 resimden 1. Spark Test, Connect the spark tester: adım 5, 2 resimden 2.
    • Connect the spark plug boot to the left terminal of the ignition checker.
  6. Spark Test: adım 6, 1 resimden 1.
    • Connect the ignition checker alligator clip to a metal surface on the motor to ground the accessory cord.
  7. Spark Test: adım 7, 1 resimden 1.
    • Set the spark gap to 6 mm by turning the spark gap adjustment knob counterclockwise.
    • Do not set the spark gap unnecessarily wide—a high voltage may damage the ignition coil.
  8. Spark Test: adım 8, 1 resimden 1.
    • Flip the power switch into the ON position.
  9. Spark Test: adım 9, 3 resimden 1. Spark Test: adım 9, 3 resimden 2. Spark Test: adım 9, 3 resimden 3.
    • Hold the spark tester by the handle on the bottom. Do not touch the terminals or spark window while the test is being conducted.
    • Watch for a spark in the spark window while a second person pulls the starter to crank the engine.
    • Consult the ignition checker instruction manual to troubleshoot the device.
Sonuç
Sam Omiotek
93.118 İtibar
290 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 12
Her zaman: 570
