Bu çeviri, kaynak kılavuzdaki en son güncellemeleri yansıtmayabilir. Çeviriyi güncellemeye yardımcı olun veya kaynak kılavuzunu görüntüleyin.
Giriş
Applicable to H4D and H4Bt engines (M281 E10 and M281 E09)
It is advisable to do this operation on a cold engine.
Recommendations :
Replace every: 60,000km/4 years (Iridium) or 20,000km (Copper/Nickel).
Electrode gap: 0.8mm (varies depending on the spark plug model considered)
H4Bt: Iridium spark plugs mandatory.
H4D: you may favor Iridium spark plugs if using E85.
See Wiki for more info.
Neye ihtiyacın var
Unscrew the 6 T50 screws by hand or using a wrench and a socket.
Lift and put aside the engine hood.
Disconnect and put aside the oil vapors duct.
Disconnect the ignition coils' connector.
Unscrew each 8mm bolts of the 3 ignition coils.
Gently extract the ignition coils.
Unscrew and extract the spark plugs using a 14mm spark plug socket.
Torque the new spark plug using a 14mm spark plug socket at 24 N.m.
Put back the ignition coils on the spark plugs.
Torque each of the 3 ignition coils' 8mm bolts at 10 N.m.
Reconnect the ignition coil's connectors.
Congratulations ! You replaced you spark plugs/ignition coils !
5 farklı kişi bu kılavuzu tamamladı.
Bu çevirmenlere özel teşekkürler:
50%
AntonioBiscuit dünyayı onarmamıza yardım ediyor! Katkıda bulunmak ister misiniz?
Çeviriye Başlayın ›
