Ana içeriğe geç
Speaker Bose SoundDock Motherboard Replacement
Neye ihtiyacın var
  1. Speaker Bose SoundDock Motherboard Replacement, Bose SoundDock Motherboard: adım 1, 2 resimden 1. Speaker Bose SoundDock Motherboard Replacement, Bose SoundDock Motherboard: adım 1, 2 resimden 2.
    • Remove the battery by pressing your finger down on the center button and twisting it counter-clockwise.
    • Remove battery and set it aside.
  2. Speaker Bose SoundDock Motherboard Replacement: adım 2, 1 resimden 1.
    • Use a plastic scraper to remove the rubber gasket from the bottom of speaker system and set it aside.
  3. Speaker Bose SoundDock Motherboard Replacement: adım 3, 1 resimden 1.
    • Use a standard sized Phillips Screwdriver to remove the four screws on the bottom of the speaker system.
  4. Speaker Bose SoundDock Motherboard Replacement: adım 4, 1 resimden 1.
    • Using a smaller flat head screw driver, unscrew the semi-circle plate from bottom to expose the motherboard.
    • Once the components are unscrewed, the plastic dock frame may fall out.
  5. Speaker Bose SoundDock Motherboard Replacement: adım 5, 1 resimden 1.
    • Gently pull both ribbon cables out of the motherboard.
  6. Speaker Bose SoundDock Motherboard Replacement: adım 6, 1 resimden 1.
    • Replace it with new motherboard by plugging in the thinner wire into the small slot, and the larger wire into the wider slot.
    • Reverse steps 1 through 4 to reassemble dock.
Sonuç
Dalton Alexandre
123 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 24-5, Green Winter 2015 Cal Poly, Team 24-5, Green Winter 2015 üyesi
CPSU-GREEN-W15S24G5
3 Üyeler
4 adet Kılavuz yazıldı
1Rehber Yorum
Where can you buy the motherboard?
Steffen Jensen - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 18
Her zaman: 3,350
