Ana içeriğe geç
Zenbre SoundBank Z3 Speaker Replacement
Neye ihtiyacın var
  1. Zenbre SoundBank Z3 Speaker Replacement, Bottom Cover: adım 1, 2 resimden 1. Zenbre SoundBank Z3 Speaker Replacement, Bottom Cover: adım 1, 2 resimden 2.
    • Power off the SoundBank Z3.
    • Turn over the device.
    • Peel the silicone feet up to remove.
    • No extra adhesive is needed to reapply the feet as long as the sticky side is not touched.
  2. Zenbre SoundBank Z3 Speaker Replacement: adım 2, 1 resimden 1.
    • Remove all eight of the 11 mm Phillips screws from the bottom of the device.
  3. Zenbre SoundBank Z3 Speaker Replacement: adım 3, 2 resimden 1. Zenbre SoundBank Z3 Speaker Replacement: adım 3, 2 resimden 2.
    • Remove the bottom panel speaker using an iFixit opening tool.
  4. Zenbre SoundBank Z3 Speaker Replacement, Motherboard Cover: adım 4, 3 resimden 1. Zenbre SoundBank Z3 Speaker Replacement, Motherboard Cover: adım 4, 3 resimden 2. Zenbre SoundBank Z3 Speaker Replacement, Motherboard Cover: adım 4, 3 resimden 3.
    • Remove the four 4.5 mm silver Phillips screws that secure the plastic panel covering the motherboard.
    • Remove the plastic panel.
  5. Zenbre SoundBank Z3 Speaker Replacement, Speakers: adım 5, 2 resimden 1. Zenbre SoundBank Z3 Speaker Replacement, Speakers: adım 5, 2 resimden 2.
    • Remove the three screws that are holding the speaker down.
    • Be careful not to rip out the speaker while taking out the screws.
  6. Zenbre SoundBank Z3 Speaker Replacement: adım 6, 2 resimden 1. Zenbre SoundBank Z3 Speaker Replacement: adım 6, 2 resimden 2.
    • Desolder the speaker joints from the motherboard. Follow this How To Solder guide for help with desoldering.
  7. Zenbre SoundBank Z3 Speaker Replacement: adım 7, 2 resimden 1. Zenbre SoundBank Z3 Speaker Replacement: adım 7, 2 resimden 2.
    • Remove the speaker from the motherboard.
    • Remove the speaker ring.
    • Be careful not to remove other components in the speaker.
    • Repeat Steps 5-7 with the other speaker.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Cherian Thomas
334 İtibar
5 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 3-2, Bhusal Spring 2016 UMass Dartmouth, Team 3-2, Bhusal Spring 2016 üyesi
UMASSD-BHUSAL-S16S3G2
5 Üyeler
8 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 459
