Ana içeriğe geç
Speakers
Neye ihtiyacın var
  1. Speakers, Battery: adım 1, 2 resimden 1. Speakers, Battery: adım 1, 2 resimden 2.
    • Locate the horizontal grip located on the back cover of the phone.
    • Slide the back cover down and off of the phone.
  2. Speakers: adım 2, 2 resimden 1. Speakers: adım 2, 2 resimden 2.
    • Insert a plastic opening tool into the battery release point located above the battery.
    • Pull outwards in order to release the battery.
  3. Speakers, Circuit Board Housing: adım 3, 3 resimden 1. Speakers, Circuit Board Housing: adım 3, 3 resimden 2. Speakers, Circuit Board Housing: adım 3, 3 resimden 3.
    Bu adımda kullanılan alet:
    Satın Al
    • Locate the 5 screws holding the body of the phone together.
    • The top screw will have a plastic cover, remove it using tweezers.
    • Using a Philips head screwdriver, twist counterclockwise to remove the screws.
    • Take special care with the screw located at the top of the phone. It is smaller and more likely to be damaged or improperly attached.
  4. Speakers: adım 4, 2 resimden 1. Speakers: adım 4, 2 resimden 2.
    • Lift the back cover starting at the bottom of the phone.
  5. Speakers: adım 5, 2 resimden 1. Speakers: adım 5, 2 resimden 2.
    • Remove the back cover completely from the phone.
  6. Speakers, Circuit Board: adım 6, 1 resimden 1.
    • Locate the clamp at bottom right side of the Circuit Board.
    • Pull the circuit board from the phone being cautious to pull out underneath the clamp.
  7. Speakers: adım 7, 2 resimden 1. Speakers: adım 7, 2 resimden 2.
    • Locate the ribbon connecting the circuit board to the phone display.
    • Using the spudger, disconnect the ribbon connecting the phone's display and the circuit board.
    • Remove the circuit board
  8. Speakers, Screen Cover: adım 8, 3 resimden 1. Speakers, Screen Cover: adım 8, 3 resimden 2. Speakers, Screen Cover: adım 8, 3 resimden 3.
    Satın Al
    • Locate the two rubber circles covering the screws.
    • Remove the rubber covers using tweezers.
    • Using the Phillips head screwdriver, unscrew and remove the two screws.
  9. Speakers: adım 9, 3 resimden 1. Speakers: adım 9, 3 resimden 2. Speakers: adım 9, 3 resimden 3.
    • Close the phone and gently pull outwards from the bottom left portion of the phone cover.
    • Take care not to do this with too much force, as it could crack the cover.
    • Completely remove the cover from the phone.
  10. Speakers, Screen Assembly: adım 10, 2 resimden 1. Speakers, Screen Assembly: adım 10, 2 resimden 2.
    • Locate the front music buttons.
    • Remove the music control buttons on the face of the phone.
  11. Speakers: adım 11, 2 resimden 1. Speakers: adım 11, 2 resimden 2.
    • While grasping the top and bottom sections torque the pieces until the indicated hinge has popped out. The two sections of the phone are now able to separate.
    • Make sure the right side of the hinge is removed first and not the left as you will likely damage the ribbon connection.
  12. Speakers: adım 12, 3 resimden 1. Speakers: adım 12, 3 resimden 2. Speakers: adım 12, 3 resimden 3.
    • Locate the two speakers. Using a spudger disconnect the speakers from the assembly.
    • Lift the screen assembly from the casing.
    • The screen assembly is completely removed to allow for easier access to the speaker connections when performing further repairs on the speakers.
  13. Speakers, Speakers: adım 13, 2 resimden 1. Speakers, Speakers: adım 13, 2 resimden 2.
    Satın Al
    • Use a pair of tweezers to disconnect the speaker wires from the circuit board. Note that the soldered connection must be broken for this to occur.
Sonuç
To reassemble your device, re-solder the speaker wires to the circuit board and follow the rest of the instructions in reverse order.
Jonathan Flowers
607 İtibar
6 adet Kılavuz yazıldı
Ekip
Clemson, Team 14-7, Benson Fall 2013 Clemson, Team 14-7, Benson Fall 2013 üyesi
CLEM-BENSON-F13S14G7
3 Üyeler
16 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 2
Her zaman: 352
