Ana içeriğe geç
Speed Switch
Neye ihtiyacın var
    1. Speed Switch, Switch: adım 1, 2 resimden 1. Speed Switch, Switch: adım 1, 2 resimden 2.
      • Use a phillips head screwdriver to unscrew the following 8 screws:
      • One 24mm Phillips screw
      • Six 16mm Phillips screws
      • One 9mm Phillips screw
      • Turn the drill to the other side and unscrew the marked screw using the same phillips head screwdriver. Place it with the other removed screws.
      • Keep all screws organized on a magnetic mat after removal.
      FixBot'a Sor
      Yorum Ekle
    2. Speed Switch: adım 2, 3 resimden 1. Speed Switch: adım 2, 3 resimden 2. Speed Switch: adım 2, 3 resimden 3.
      • Carefully remove the plastic drill casing by pulling it apart.
      • When separating the drill casing, the black plastic speed switch covering will be removed from the drill automatically.
      FixBot'a Sor
      Yorum Ekle
    3. Speed Switch: adım 3, 2 resimden 1. Speed Switch: adım 3, 2 resimden 2.
      • Gently remove the orange plastic speed switch from the drill. It is located right above the motor.
      FixBot'a Sor
      Yorum Ekle
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 33
Her zaman: 1,532
