Giriş
The battery is like the heart of the Sphere Ollie. Without the battery, the Ollie will be useless and inactive. To replace your battery, you will need a Blue Opening Tool and Phillip's Head Screwdriver to gain access to it.
Neye ihtiyacın var
Firmly grasp Ollie in one hand.
Remove the blue rubber tire in a peeling motion with your opposite hand.
Loosen and remove the 10mm screw on each side of the device using a JIS 1 screwdriver tip.
Remove the plastic tire frame from the device
Loosen and remove the 10mm screws holding the blue tooth connector as well as the two 1 10 screws holding the motherboard to the case using the JIS #1 screwdriver
Loosen and remove the 10mm screws holding the antenna to the case.
Gently remove mother board from the case with an upward motion.
After you have removed the motherboard, use a JIS #1 screwdriver to remove the four 10mm Screws holding in the cog shields.
Next, you want to pull apart the clips (two on each side) holding the top piece of the shield to the frame.
Then, once you have freed the cogs, you can lift the cog and remove it from the frame.
13 farklı kişi bu kılavuzu tamamladı.
7 Yorum
Alex,
Amazon (Uxcell Power Supply DC 3.7 V 1000 MAh 803040 Li-ion rechargeable lithium Polymer Li- Po Battery
Yes I need to find a battery as well
Need a battery email me terrys2207@yahoo.co.uk
Can I get a motherboard replaced in ollie. Please help me with reply to my email sgandham1980@icloud.com
