Ana içeriğe geç
Sphero Ollie Motherboard Replacement
Neye ihtiyacın var
  1. Sphero Ollie Motherboard Replacement, Tires and Hubcaps: adım 1, 1 resimden 1.
    • Firmly grasp Ollie in one hand.
    • Remove the blue rubber tire in a peeling motion with your opposite hand.
  2. Sphero Ollie Motherboard Replacement: adım 2, 2 resimden 1. Sphero Ollie Motherboard Replacement: adım 2, 2 resimden 2.
    • Continue to firmly hold Ollie in one hand.
    • Use a Plastic Opening Tool to gently pry off the hubcap.
    • Avoid inserting the Plastic Opening Tool into the empty holes, but instead use the tool near the tabs holding the hubcap in.
    • Do not aim the hubcap towards another person as it may pop off with force.
  3. Sphero Ollie Motherboard Replacement, Motherboard: adım 3, 1 resimden 1.
    • Loosen and remove the 10mm screw on each side of the device using a JIS 1 screwdriver tip.
    • Remove the plastic tire frame from the device
  4. Sphero Ollie Motherboard Replacement: adım 4, 2 resimden 1. Sphero Ollie Motherboard Replacement: adım 4, 2 resimden 2.
    • Loosen and remove the four 10mm Screws on the underside of the device using a JIS 1 tip.
    • Firmly grasp the bottom of the device and pull the top half of the outer case off of the bottom.
  5. Sphero Ollie Motherboard Replacement: adım 5, 2 resimden 1. Sphero Ollie Motherboard Replacement: adım 5, 2 resimden 2.
    • Loosen and remove the 10mm screws holding the blue tooth connector as well as the two 1 10 screws holding the motherboard to the case using the JIS #1 screwdriver
    • Loosen and remove the 10mm screws holding the antenna to the case.
    • Gently remove mother board from the case with an upward motion.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Krystal Hedrick
361 İtibar
3 adet Kılavuz yazıldı
Ekip
UW Tacoma, Team S1-G3, Rose Fall 2017 UW Tacoma, Team S1-G3, Rose Fall 2017 üyesi
UWT-ROSE-F17S1G3
4 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 692
