Ana içeriğe geç
Spigen Kuel TS36 Car Mount Spring Replacement
Neye ihtiyacın var
  1. Spigen Kuel TS36 Car Mount Spring Replacement, Spring/coil: adım 1, 2 resimden 1. Spigen Kuel TS36 Car Mount Spring Replacement, Spring/coil: adım 1, 2 resimden 2.
    • Pull the phone holder off the mount by applying force; the parts will not actually break from the pressure. Temporarily remove the two round half-socket covers on the ball socket, as they are prone to slipping off.
  2. Spigen Kuel TS36 Car Mount Spring Replacement: adım 2, 1 resimden 1.
    • Remove four 5.0 mm screws from the backing panel of the phone holder using the Oval shape screwhead. Push out wing panels to release the mechanism, and remove the screws and holder from the backing panel.
  3. Spigen Kuel TS36 Car Mount Spring Replacement: adım 3, 2 resimden 1. Spigen Kuel TS36 Car Mount Spring Replacement: adım 3, 2 resimden 2.
    • If either of the springs have not ejected from their slots, proceed to pull them out gently so that the chassis the wing panels are connected to remain undisturbed.
  4. Spigen Kuel TS36 Car Mount Spring Replacement: adım 4, 2 resimden 1. Spigen Kuel TS36 Car Mount Spring Replacement: adım 4, 2 resimden 2.
    • Insert two new 2.6 cm springs as you would batteries to a tv remote. Be cautious as to keep the chassis in place during this process.
  5. Spigen Kuel TS36 Car Mount Spring Replacement: adım 5, 2 resimden 1. Spigen Kuel TS36 Car Mount Spring Replacement: adım 5, 2 resimden 2.
    • Pull out of the wing panels to re-engage the mechanism, holding the center of panels down.
    • The backing panel will not be able to properly be reattached unless the mechanism is is engaged, and the springs are bunched.
  6. Spigen Kuel TS36 Car Mount Spring Replacement: adım 6, 2 resimden 1. Spigen Kuel TS36 Car Mount Spring Replacement: adım 6, 2 resimden 2.
    • Slide the backing panel over the frame of the holder, aligning the sides. Press the button on the center of the holder to once again disengage the mechanism. This will allow the panel to fully slide back into place.
  7. Spigen Kuel TS36 Car Mount Spring Replacement: adım 7, 1 resimden 1.
    • Rescrew backing with oval head screwdriver to reassemble the phone holder’s backing.
  8. Spigen Kuel TS36 Car Mount Spring Replacement: adım 8, 2 resimden 1. Spigen Kuel TS36 Car Mount Spring Replacement: adım 8, 2 resimden 2.
    • With moderate to heavy force, apply pressure to the ball joint into the socket.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Ramy Huynh
172 İtibar
1 Kılavuz yazıldı
Ekip
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 7
Son 30 gün: 12
Her zaman: 1,156
