Ana içeriğe geç
Spin Master Boxer Remote Trigger Buttons Replacement
Neye ihtiyacın var
  1. Spin Master Boxer Remote Trigger Buttons Replacement, Remote Trigger Buttons: adım 1, 1 resimden 1.
    • Lay the remote flat on your work space, with joysticks facing you.
    FixBot'a Sor
    Yorum Ekle
  2. Spin Master Boxer Remote Trigger Buttons Replacement: adım 2, 1 resimden 1.
    • Remove both joysticks by gripping under circular knob and gently pulling towards you.
    • The joysticks should detach without much effort.
    FixBot'a Sor
    Yorum Ekle
  3. Spin Master Boxer Remote Trigger Buttons Replacement: adım 3, 1 resimden 1.
    • Use the Phillips #00 Screwdriver to remove 4mm screw on the center battery panel.
    • Remove the batteries from the remote and set it to side.
    • Use the same screwdriver to remove all four 4mm screws on back panel.
    FixBot'a Sor
    Yorum Ekle
  4. Spin Master Boxer Remote Trigger Buttons Replacement: adım 4, 2 resimden 1. Spin Master Boxer Remote Trigger Buttons Replacement: adım 4, 2 resimden 2.
    • Insert the Jimmy in between the top panel and the bottom panel.
    • Gently use the Jimmy to separate both plastic panels from each other.
    • Pull the panels apart and set bottom piece on workbench.
    FixBot'a Sor
    Yorum Ekle
  5. Spin Master Boxer Remote Trigger Buttons Replacement: adım 5, 2 resimden 1. Spin Master Boxer Remote Trigger Buttons Replacement: adım 5, 2 resimden 2.
    • Pinch the trigger between index finger and thumb, and lift up, away from circuit board.
    • Inspect the square button attached to circuit board to ensure functionality. If there is an issue with connection, a new circuit boards may be required.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Lauren Roide
769 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S1-G1, Maness Spring 2019 Cal Poly, Team S1-G1, Maness Spring 2019 üyesi
CPSU-MANESS-S19S1G1
4 Üyeler
10 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 6
Son 30 gün: 31
Her zaman: 1,291
