Ana içeriğe geç
Spin Master Hatchimal Draggle Wheels Replacement
Neye ihtiyacın var
  1. Spin Master Hatchimal Draggle Wheels Replacement, Plastic Wing Replacement: adım 1, 1 resimden 1.
    • lay the Hatchimal on its side.
  2. Spin Master Hatchimal Draggle Wheels Replacement: adım 2, 1 resimden 1.
    • Using the plastic opening tool, push in on the purple clip.
  3. Spin Master Hatchimal Draggle Wheels Replacement: adım 3, 1 resimden 1.
    • Pull the wing off of the hatchimal.
    • The wing should come off with little resistance.
  4. Spin Master Hatchimal Draggle Wheels Replacement, Fur Replacement: adım 4, 2 resimden 1. Spin Master Hatchimal Draggle Wheels Replacement, Fur Replacement: adım 4, 2 resimden 2.
    • Cut the fur retaining zip-tie with a pair of scissors.
  5. Spin Master Hatchimal Draggle Wheels Replacement: adım 5, 2 resimden 1. Spin Master Hatchimal Draggle Wheels Replacement: adım 5, 2 resimden 2.
    • Lift the fur up until it can't go further.
  6. Spin Master Hatchimal Draggle Wheels Replacement: adım 6, 3 resimden 1. Spin Master Hatchimal Draggle Wheels Replacement: adım 6, 3 resimden 2. Spin Master Hatchimal Draggle Wheels Replacement: adım 6, 3 resimden 3.
    • Use the spudger tool to push up on the black clip to free it.
    • Pull the clip out.
  7. Spin Master Hatchimal Draggle Wheels Replacement: adım 7, 3 resimden 1. Spin Master Hatchimal Draggle Wheels Replacement: adım 7, 3 resimden 2. Spin Master Hatchimal Draggle Wheels Replacement: adım 7, 3 resimden 3.
    • Lift fur up to reveal the next set of clips.
    • Insert a spudger to push up on the black clip to free it.
    • Pull out the clip.
  8. Spin Master Hatchimal Draggle Wheels Replacement: adım 8, 2 resimden 1. Spin Master Hatchimal Draggle Wheels Replacement: adım 8, 2 resimden 2.
    • Lift the fur up and over the Hatchimals Head.
    • Remove the six 12mm Phillips #00 screws from then body.
  9. Spin Master Hatchimal Draggle Wheels Replacement: adım 9, 2 resimden 1. Spin Master Hatchimal Draggle Wheels Replacement: adım 9, 2 resimden 2.
    • Pull the casing apart.
    • Remove the yellow speaker cable.
  10. Spin Master Hatchimal Draggle Wheels Replacement: adım 10, 3 resimden 1. Spin Master Hatchimal Draggle Wheels Replacement: adım 10, 3 resimden 2. Spin Master Hatchimal Draggle Wheels Replacement: adım 10, 3 resimden 3.
    • Remove the three 7mm Phillips #00 screws from the head.
    • Remove the wheel base and the circuit board carefully not to damage the spring.
  11. Spin Master Hatchimal Draggle Wheels Replacement: adım 11, 2 resimden 1. Spin Master Hatchimal Draggle Wheels Replacement: adım 11, 2 resimden 2.
    • Push the six black fur clips out using the spudger.
    • Remove the fur completely.
  12. Spin Master Hatchimal Draggle Wheels Replacement, Wheel Replacement: adım 12, 2 resimden 1. Spin Master Hatchimal Draggle Wheels Replacement, Wheel Replacement: adım 12, 2 resimden 2.
    • Lift up and remove the light blue plastic casing.
  13. Spin Master Hatchimal Draggle Wheels Replacement: adım 13, 2 resimden 1. Spin Master Hatchimal Draggle Wheels Replacement: adım 13, 2 resimden 2.
    • Remove the six 7mm Phillips #00 screws.
  14. Spin Master Hatchimal Draggle Wheels Replacement: adım 14, 2 resimden 1. Spin Master Hatchimal Draggle Wheels Replacement: adım 14, 2 resimden 2.
    • Remove the purple plastic casing. It should come off with little resistance.
    • Remove the wheel.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Humaid Alhajri
115 İtibar
1 Kılavuz yazıldı
Ekip
USF Tampa, Team S1-G5, Nance Spring 2018 USF Tampa, Team S1-G5, Nance Spring 2018 üyesi
USFT-NANCE-S18S1G5
3 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 12
Son 30 gün: 18
Her zaman: 1,138
