Ana içeriğe geç
Spiral Bound Notebook Cover Replacement
Neye ihtiyacın var
  1. Spiral Bound Notebook Cover Replacement, Cover: adım 1, 2 resimden 1. Spiral Bound Notebook Cover Replacement, Cover: adım 1, 2 resimden 2.
    • Use a binder clip on either end to hold the paper block together, excluding the damaged cover.
  2. Spiral Bound Notebook Cover Replacement: adım 2, 3 resimden 1. Spiral Bound Notebook Cover Replacement: adım 2, 3 resimden 2. Spiral Bound Notebook Cover Replacement: adım 2, 3 resimden 3.
    • Uncoil the free end of the spiral.
  3. Spiral Bound Notebook Cover Replacement: adım 3, 3 resimden 1. Spiral Bound Notebook Cover Replacement: adım 3, 3 resimden 2. Spiral Bound Notebook Cover Replacement: adım 3, 3 resimden 3.
    • Push the spiral end back through the binding hole and pull it out.
  4. Spiral Bound Notebook Cover Replacement: adım 4, 1 resimden 1.
    • Repeat previous step until spiral is removed.
  5. Spiral Bound Notebook Cover Replacement: adım 5, 1 resimden 1.
    • Take the damaged cover and place it over the cardstock, aligning them at the edges.
  6. Spiral Bound Notebook Cover Replacement: adım 6, 3 resimden 1. Spiral Bound Notebook Cover Replacement: adım 6, 3 resimden 2. Spiral Bound Notebook Cover Replacement: adım 6, 3 resimden 3.
    • Trace the cover edges.
  7. Spiral Bound Notebook Cover Replacement: adım 7, 2 resimden 1. Spiral Bound Notebook Cover Replacement: adım 7, 2 resimden 2.
    • Trace the cover binding holes.
  8. Spiral Bound Notebook Cover Replacement: adım 8, 3 resimden 1. Spiral Bound Notebook Cover Replacement: adım 8, 3 resimden 2. Spiral Bound Notebook Cover Replacement: adım 8, 3 resimden 3.
    • Using a hole punch, punch out the traced holes on the cardstock sheet.
  9. Spiral Bound Notebook Cover Replacement: adım 9, 3 resimden 1. Spiral Bound Notebook Cover Replacement: adım 9, 3 resimden 2. Spiral Bound Notebook Cover Replacement: adım 9, 3 resimden 3.
    • Cut off the traced edges on the cardstock sheet.
  10. Spiral Bound Notebook Cover Replacement: adım 10, 2 resimden 1. Spiral Bound Notebook Cover Replacement: adım 10, 2 resimden 2.
    • Without removing the binding clip, open it and slide the cardstock onto the paper block while making sure their holes aligned.
  11. Spiral Bound Notebook Cover Replacement: adım 11, 3 resimden 1. Spiral Bound Notebook Cover Replacement: adım 11, 3 resimden 2. Spiral Bound Notebook Cover Replacement: adım 11, 3 resimden 3.
    • Perform Steps 1 through 4 in reverse to complete the replacement.
Sonuç
To reassemble your device, follow instructions 1 - 4 in reverse order.
Bir başkası bu kılavuzu tamamladı.
Abel Mbaziira
220 İtibar
1 Kılavuz yazıldı
Ekip
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 33
Son 30 gün: 145
Her zaman: 2,244
