Giriş
A damaged/ripped notebook cover leaves its important contents exposed and at risk.
With a proper cover, you can ensure the contents are safely preserved for the future.
With the help of this guide, replace the damaged cover on your spiral bound notebook.
Neye ihtiyacın var
Use a binder clip on either end to hold the paper block together, excluding the damaged cover.
To reassemble your device, follow instructions 1 - 4 in reverse order.
Bir başkası bu kılavuzu tamamladı.
