Ana içeriğe geç
Sprinkler Head Replacement
Neye ihtiyacın var
  1. Sprinkler Head Replacement, Sprinkler Head: adım 1, 1 resimden 1.
    • Turn off the water supply to the sprinklers.
    • This process will vary depending on your sprinkler controller.
  2. Sprinkler Head Replacement: adım 2, 1 resimden 1.
    • Find where the water supply feeds the sprinkler system and close the valve in the event of emergency or unforeseen circumstances.
  3. Sprinkler Head Replacement: adım 3, 1 resimden 1.
    • Dig a hole down to the base of the sprinkler head.
    • Be careful to avoid puncturing the sprinkler line.
  4. Sprinkler Head Replacement: adım 4, 1 resimden 1.
    • Using your hand or a gardening trowel, finish digging so that the sprinkler head is fully visible and is clear of dirt and debris.
  5. Sprinkler Head Replacement: adım 5, 2 resimden 1. Sprinkler Head Replacement: adım 5, 2 resimden 2.
    • Unscrew the sprinkler head from the line it is attached to.
    • If is loose enough you may not need pliers.
  6. Sprinkler Head Replacement: adım 6, 2 resimden 1. Sprinkler Head Replacement: adım 6, 2 resimden 2.
    • Coat the threads of the water line with teflon tape to avoid leaking.
  7. Sprinkler Head Replacement: adım 7, 2 resimden 1. Sprinkler Head Replacement: adım 7, 2 resimden 2.
    • Using your hand, screw the new sprinkler head on over the teflon tape.
    • Once the sprinkler head is hand tight, use pliers to tighten it by another half turn.
  8. Sprinkler Head Replacement: adım 8, 1 resimden 1.
    • Fill the hole in and pack it down to avoid unwanted movement of the new sprinkler head.
  9. Sprinkler Head Replacement: adım 9, 1 resimden 1.
    • Turn the sprinkler system on.
  10. Sprinkler Head Replacement: adım 10, 1 resimden 1.
    • Twist the top of the sprinkler until it is aimed where you want it.
  11. Sprinkler Head Replacement: adım 11, 1 resimden 1.
    • Use a flat head screwdriver to adjust the flow of water if needed.
    • Turning right decreases the water flow. Turning left increases the water flow.
Sonuç
Enjoy your green lawn and water savings.
Bir başkası bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 3
Son 30 gün: 12
Her zaman: 570
