Ana içeriğe geç
Sprint Sanyo RL-4920 Display Replacement
Neye ihtiyacın var
  1. Sprint Sanyo RL-4920 Display Replacement, Back of Phone: adım 1, 1 resimden 1.
    • Flip the phone over so that the screen is facing down.
  2. Sprint Sanyo RL-4920 Display Replacement, Remove Battery Pack: adım 2, 2 resimden 1. Sprint Sanyo RL-4920 Display Replacement, Remove Battery Pack: adım 2, 2 resimden 2.
    • Push the gray lever up towards the top of the phone.
    • Pull up on the battery pack and completely separate it from the phone.
  3. Sprint Sanyo RL-4920 Display Replacement, Screws: adım 3, 2 resimden 1. Sprint Sanyo RL-4920 Display Replacement, Screws: adım 3, 2 resimden 2.
    • Locate the five screws around the back casing.
    • Use a three-prong screw bit to remove all five screws.
  4. Sprint Sanyo RL-4920 Display Replacement, Separate Cases: adım 4, 1 resimden 1.
    • Use the plastic opening tool and slide it around the phone to pull apart the front and back casing.
  5. Sprint Sanyo RL-4920 Display Replacement, Separate Cases: adım 5, 1 resimden 1.
    • Separate the two cases.
  6. Sprint Sanyo RL-4920 Display Replacement, The Front Case: adım 6, 1 resimden 1.
    • Use the plastic opening tool to remove the motherboard from the front case.
  7. Sprint Sanyo RL-4920 Display Replacement, Display: adım 7, 2 resimden 1. Sprint Sanyo RL-4920 Display Replacement, Display: adım 7, 2 resimden 2.
    • Locate the 4 white clips of the dispaly.
  8. Sprint Sanyo RL-4920 Display Replacement: adım 8, 2 resimden 1. Sprint Sanyo RL-4920 Display Replacement: adım 8, 2 resimden 2.
    • Using the plastic opening tool, pull the white clips of the display away from the printed circuit board to unclip display.
  9. Sprint Sanyo RL-4920 Display Replacement: adım 9, 2 resimden 1. Sprint Sanyo RL-4920 Display Replacement: adım 9, 2 resimden 2.
    • Grasp the display on both sides and carefully pull the display off of the printed circuit board.
  10. Sprint Sanyo RL-4920 Display Replacement: adım 10, 2 resimden 1. Sprint Sanyo RL-4920 Display Replacement: adım 10, 2 resimden 2.
    • Using the plastic opening tool, carefully remove the yellow film covering the display connector.
    • Do not damage the yellow film. Ensure that it stays in one piece and does not tear.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Patrick Olmstead
240 İtibar
2 adet Kılavuz yazıldı
Ekip
Clemson, Team 13-5, Benson Fall 2013 Clemson, Team 13-5, Benson Fall 2013 üyesi
CLEM-BENSON-F13S13G5
3 Üyeler
12 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 3
Her zaman: 257
