Ana içeriğe geç
Sprint Sanyo RL-4920 Replacing Rubber Keys Replacement
Neye ihtiyacın var
  1. Sprint Sanyo RL-4920 Replacing Rubber Keys Replacement, Back of Phone: adım 1, 1 resimden 1.
    • Flip the phone over so that the screen is facing down.
  2. Sprint Sanyo RL-4920 Replacing Rubber Keys Replacement, Remove Battery Pack: adım 2, 2 resimden 1. Sprint Sanyo RL-4920 Replacing Rubber Keys Replacement, Remove Battery Pack: adım 2, 2 resimden 2.
    • Push the gray lever up towards the top of the phone.
    • Pull up on the battery pack and completely separate it from the phone.
  3. Sprint Sanyo RL-4920 Replacing Rubber Keys Replacement, Screws: adım 3, 2 resimden 1. Sprint Sanyo RL-4920 Replacing Rubber Keys Replacement, Screws: adım 3, 2 resimden 2.
    • Locate the five screws around the back casing.
    • Use a three-prong screw bit to remove all five screws.
  4. Sprint Sanyo RL-4920 Replacing Rubber Keys Replacement, Separate Cases: adım 4, 1 resimden 1.
    • Use the plastic opening tool and slide it around the phone to pull apart the front and back casing.
  5. Sprint Sanyo RL-4920 Replacing Rubber Keys Replacement, Separate Cases: adım 5, 1 resimden 1.
    • Separate the two cases.
  6. Sprint Sanyo RL-4920 Replacing Rubber Keys Replacement, The Front Case: adım 6, 1 resimden 1.
    • Use the plastic opening tool to remove the motherboard from the front case.
  7. Sprint Sanyo RL-4920 Replacing Rubber Keys Replacement, Rubber Keys: adım 7, 1 resimden 1.
    • The plastic keys are attached to the back side of the front case. To remove the keys, pull the plastic piece out of the front case using the plastic opening tool.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Katherine Rieck
101 İtibar
1 Kılavuz yazıldı
Ekip
Clemson, Team 13-5, Benson Fall 2013 Clemson, Team 13-5, Benson Fall 2013 üyesi
CLEM-BENSON-F13S13G5
3 Üyeler
12 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 5
Her zaman: 139
