Ana içeriğe geç
Sprint Sanyo RL-4920 Vibrator Motor Replacement
Neye ihtiyacın var
  1. Sprint Sanyo RL-4920 Vibrator Motor Replacement, Back of Phone: adım 1, 1 resimden 1.
    • Flip the phone over so that the screen is facing down.
  2. Sprint Sanyo RL-4920 Vibrator Motor Replacement, Remove Battery Pack: adım 2, 2 resimden 1. Sprint Sanyo RL-4920 Vibrator Motor Replacement, Remove Battery Pack: adım 2, 2 resimden 2.
    • Push the gray lever up towards the top of the phone.
    • Pull up on the battery pack and completely separate it from the phone.
  3. Sprint Sanyo RL-4920 Vibrator Motor Replacement, Screws: adım 3, 2 resimden 1. Sprint Sanyo RL-4920 Vibrator Motor Replacement, Screws: adım 3, 2 resimden 2.
    • Locate the five screws around the back casing.
    • Use a three-prong screw bit to remove all five screws.
  4. Sprint Sanyo RL-4920 Vibrator Motor Replacement, Separate Cases: adım 4, 1 resimden 1.
    • Use the plastic opening tool and slide it around the phone to pull apart the front and back casing.
  5. Sprint Sanyo RL-4920 Vibrator Motor Replacement, Separate Cases: adım 5, 1 resimden 1.
    • Separate the two cases.
  6. Sprint Sanyo RL-4920 Vibrator Motor Replacement, The Front Case: adım 6, 1 resimden 1.
    • Use the plastic opening tool to remove the motherboard from the front case.
  7. Sprint Sanyo RL-4920 Vibrator Motor Replacement, Display: adım 7, 2 resimden 1. Sprint Sanyo RL-4920 Vibrator Motor Replacement, Display: adım 7, 2 resimden 2.
    • Locate the 4 white clips of the dispaly.
  8. Sprint Sanyo RL-4920 Vibrator Motor Replacement: adım 8, 2 resimden 1. Sprint Sanyo RL-4920 Vibrator Motor Replacement: adım 8, 2 resimden 2.
    • Using the plastic opening tool, pull the white clips of the display away from the printed circuit board to unclip display.
  9. Sprint Sanyo RL-4920 Vibrator Motor Replacement: adım 9, 2 resimden 1. Sprint Sanyo RL-4920 Vibrator Motor Replacement: adım 9, 2 resimden 2.
    • Grasp the display on both sides and carefully pull the display off of the printed circuit board.
  10. Sprint Sanyo RL-4920 Vibrator Motor Replacement: adım 10, 2 resimden 1. Sprint Sanyo RL-4920 Vibrator Motor Replacement: adım 10, 2 resimden 2.
    • Using the plastic opening tool, carefully remove the yellow film covering the display connector.
    • Do not damage the yellow film. Ensure that it stays in one piece and does not tear.
  11. Sprint Sanyo RL-4920 Vibrator Motor Replacement, Vibrator Motor: adım 11, 1 resimden 1.
    • Use a Phillips-head screw bit to remove the screw under the yellow film
  12. Sprint Sanyo RL-4920 Vibrator Motor Replacement: adım 12, 3 resimden 1. Sprint Sanyo RL-4920 Vibrator Motor Replacement: adım 12, 3 resimden 2. Sprint Sanyo RL-4920 Vibrator Motor Replacement: adım 12, 3 resimden 3.
    • Use the spudger tool to pry the latches ways from the circuit board
    • Detach the metal casing from the circuit board
  13. Sprint Sanyo RL-4920 Vibrator Motor Replacement: adım 13, 2 resimden 1. Sprint Sanyo RL-4920 Vibrator Motor Replacement: adım 13, 2 resimden 2.
    • Remove wires attaching vibrator motor to circuit board gently so as not to damage them
  14. Sprint Sanyo RL-4920 Vibrator Motor Replacement: adım 14, 3 resimden 1. Sprint Sanyo RL-4920 Vibrator Motor Replacement: adım 14, 3 resimden 2. Sprint Sanyo RL-4920 Vibrator Motor Replacement: adım 14, 3 resimden 3.
    • Once the metal casing is removed from the circuit board take it and locate the vibrator motor on the top side of the casing
    • Use the spudger tool to gently pry the vibrator motor out of its protective shell
  15. Sprint Sanyo RL-4920 Vibrator Motor Replacement: adım 15, 1 resimden 1.
    • With the vibrator motor completely removed, you can now replace it with a new one
Sonuç
Bir başkası bu kılavuzu tamamladı.
Austin Shores
301 İtibar
3 adet Kılavuz yazıldı
Ekip
Clemson, Team 13-5, Benson Fall 2013 Clemson, Team 13-5, Benson Fall 2013 üyesi
CLEM-BENSON-F13S13G5
3 Üyeler
12 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 6
Her zaman: 308
