Ana içeriğe geç
Eşyalarını Tamir Et
Onarma Hakkı
Parçalar ve Aletler
Giriş
The battery is fairly easy to replace the only issue with taking it out is the adhesive holding it in. the best way to do this is to heat it up, recommended tool is the iopener and the mettle spudger.
Parçalar
Hiçbir parça belirtilmedi.
  1. Use an opening tool to push in and release sixteen small plastic clips around the edge of the case. As the clips are released, gradually pry the case apart. It is easiest to start on the corners.
    • Use an opening tool to push in and release sixteen small plastic clips around the edge of the case. As the clips are released, gradually pry the case apart.
    • It is easiest to start on the corners.
  2. Remove the black electrical tape over the ribbon connector. Remove the ribbon connector over the battery.
    • Remove the black electrical tape over the ribbon connector.
    • Remove the ribbon connector over the battery.
    • Make sure to be careful of the ribbon connector while working on the device.
  3. LCD iPhone Ekran Tamir Kit'leri
    Ömür Boyu Garantimiz kapsamındaki bütçe seçeneği.
    Shop Kits
    Onarım maliyetlerini düşürün, kaliteyi değil.
    Shop Kits
  4. Next you must heat up the battery to help weaken the adhesive connecting the battery to the device.
    • Next you must heat up the battery to help weaken the adhesive connecting the battery to the device.
  5. Once this is done start to pry the battery away from the device carefully. It helps to start at the corners and move inward.
    • Once this is done start to pry the battery away from the device carefully. It helps to start at the corners and move inward.
  6. Once you remove the battery from the device it is still connected by three wires: red, black, and, white. It is important to remember the order they are in when reconnecting the new battery. Once you remove the battery from the device it is still connected by three wires: red, black, and, white. It is important to remember the order they are in when reconnecting the new battery.
    • Once you remove the battery from the device it is still connected by three wires: red, black, and, white. It is important to remember the order they are in when reconnecting the new battery.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
jasen biggins
723 İtibar
5 adet Kılavuz yazıldı
Takım
USF Tampa, Team 14-101, Meier Fall 2015 USF Tampa, Team 14-101, Meier Fall 2015 üyesi
USFT-MEIER-F15S14G101
4 Üyeler
12 adet Kılavuz yazıldı
6 Yorum
Ours is only 6 months old. It only works when it stays plugged in. Battery is bad?
Rachel - Yanıt
I had the same problem, only played while plugged in and would not charge.. I found that the battery wires while appearing tight one wire had broken inside the wire insulation at the solder pad on the main board. When I redid the connection it charges, and works well. 8/11/16
larrywb135 -
My grand daughters won't come on, should I take it to an electronic store?. I don't want to try and pry it open, for fear I may make it worse, she loves her tablet, and it is very helpful for her with school, she's had it 2 years and I put it away for about 8 month, for going on line, without permission, I gave it back in Sept. Now its not charging or coming on. Thank you.Deborah
jacksondebo2010 - Yanıt
Where can I get a battery?
crzyinind - Yanıt
You can get one at Amazon, EBay and more.
Kat Marin -
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 7
Her zaman: 3,155
