Ana içeriğe geç
Sprout Channel Cubby Camera Replacement
Neye ihtiyacın var
  1. Sprout Channel Cubby Camera Replacement, Dissasemble the device: adım 1, 2 resimden 1. Sprout Channel Cubby Camera Replacement, Dissasemble the device: adım 1, 2 resimden 2.
    • Use an opening tool to push in and release sixteen small plastic clips around the edge of the case. As the clips are released, gradually pry the case apart.
    • It is easiest to start on the corners.
    FixBot'a Sor
    Yorum Ekle
  2. Sprout Channel Cubby Camera Replacement, Remove the screw: adım 2, 1 resimden 1.
    • Remove the single screw attaching the camera to the device.
    FixBot'a Sor
    Yorum Ekle
  3. Sprout Channel Cubby Camera Replacement, Remove the camera: adım 3, 1 resimden 1.
    FixBot'a Sor
    Yorum Ekle
Sonuç
jasen biggins
741 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 14-101, Meier Fall 2015 USF Tampa, Team 14-101, Meier Fall 2015 üyesi
USFT-MEIER-F15S14G101
4 Üyeler
12 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 15
Her zaman: 586
