Ana içeriğe geç
Sprout Channel Cubby Digitizer Replacement
Neye ihtiyacın var
    1. Sprout Channel Cubby Digitizer Replacement, Dissasemble the device: adım 1, 2 resimden 1. Sprout Channel Cubby Digitizer Replacement, Dissasemble the device: adım 1, 2 resimden 2.
      • Use an opening tool to push in and release sixteen small plastic clips around the edge of the case. As the clips are released, gradually pry the case apart.
      • It is easiest to start on the corners.
      FixBot'a Sor
      Yorum Ekle
    1. Sprout Channel Cubby Digitizer Replacement, Digitizer: adım 2, 1 resimden 1.
      • Once opened, carefully peel back the black electric tape around the digitizer.
      FixBot'a Sor
      Yorum Ekle
    2. Sprout Channel Cubby Digitizer Replacement: adım 3, 1 resimden 1.
      • Unclasp the electrical plastic strip by gently pulling up on the white colored clasp.
      FixBot'a Sor
      Yorum Ekle
    3. Sprout Channel Cubby Digitizer Replacement: adım 4, 1 resimden 1.
      • Unscrew the five screws holding down the motherboard.
      FixBot'a Sor
      Yorum Ekle
    4. Sprout Channel Cubby Digitizer Replacement: adım 5, 1 resimden 1.
      • Once all five screws are removed, you should be able to lift up the motherboard.
      FixBot'a Sor
      Yorum Ekle
    5. Sprout Channel Cubby Digitizer Replacement: adım 6, 1 resimden 1.
      • Remove the four remaining screws.
      • This can be done with the battery still attached but is easier if it is unattached.
      FixBot'a Sor
      Yorum Ekle
    6. Sprout Channel Cubby Digitizer Replacement: adım 7, 1 resimden 1.
      • Remove the metal sheet covering the screen and digitizer.
      • Removing the screen is a very fragile process and needs to be done slowly. The nylon spudger is the best tool for this.
      FixBot'a Sor
      Yorum Ekle
    7. Sprout Channel Cubby Digitizer Replacement: adım 8, 2 resimden 1. Sprout Channel Cubby Digitizer Replacement: adım 8, 2 resimden 2.
      • Remove all of the white pegs located along the perimeter of the plastic. You'll need to remove all of the pegs to remove the white front face.
      FixBot'a Sor
      Yorum Ekle
    8. Sprout Channel Cubby Digitizer Replacement: adım 9, 2 resimden 1. Sprout Channel Cubby Digitizer Replacement: adım 9, 2 resimden 2.
      • To take out the digitizer, remove the connector ribbon from the plastic and then slowly apply pressure to the corner and edges of the digitizer.
      FixBot'a Sor
      Yorum Ekle
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
David Meyers
244 İtibar
1 Kılavuz yazıldı
Ekip
USF Tampa, Team 14-101, Meier Fall 2015 USF Tampa, Team 14-101, Meier Fall 2015 üyesi
USFT-MEIER-F15S14G101
4 Üyeler
12 adet Kılavuz yazıldı
4Kılavuz Yorumları
Ok I opened up the back and I accidentally pressed a little on the battery and now my screen is all white no picture. What did I do is there a way to fix the picture?
deysi gallegos - Yanıt Paylaş
Most likely the LCD is broken and needs to be replaced.
Stephen Martinez - Yanıt Paylaş
You don't need to remove the mother board or the battery from the LCD to replace the digitizer. Once you remove the screws from the motherboard you can lift it up to access the screw for the front bezel and access the bezel clips underneath. Taking the battery off the LCD will most likely damage the LCD, so don't even mess with it. After you have the front bezel removed, flip the entire assembly over and you can replace the digitizer. Make sure you remove all the black foam and adhesive from the case after the digitizer is removed. This makes assembly easier and prevents damage to the new digitizer.
I replaced my digitizer screen and it is still not working, what is the screen under the first screen called and it is still showing a dysfunctional screen
pam - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 6
Son 30 gün: 24
Her zaman: 4,265
