Giriş
The replacement for the speaker is rather simple. However, soldering is necessary when attaching the new speaker.
Neye ihtiyacın var
Use an opening tool to push in and release sixteen small plastic clips around the edge of the case. As the clips are released, gradually pry the case apart.
While using the spatula, slowly get under the top part of the speaker. Then slowly move down the speaker to detach it from the device (there is a small amount of adhesive).
Bir başkası bu kılavuzu tamamladı.
2Kılavuz Yorumları
Jasen, where can I purchase the replacement speaker for the Sprout?
There is no way that I would want to take apart a new tablet to replaceor repair the speakers. Why not install it correctly the first time? Appears to be an ongoing issue.
