Ana içeriğe geç
Sprout Channel Cubby Speaker Replacement
Neye ihtiyacın var
  1. Sprout Channel Cubby Speaker Replacement, Dissasemble the device: adım 1, 2 resimden 1. Sprout Channel Cubby Speaker Replacement, Dissasemble the device: adım 1, 2 resimden 2.
    • Use an opening tool to push in and release sixteen small plastic clips around the edge of the case. As the clips are released, gradually pry the case apart.
    • It is easiest to start on the corners.
  2. Sprout Channel Cubby Speaker Replacement, Speaker: adım 2, 2 resimden 1. Sprout Channel Cubby Speaker Replacement, Speaker: adım 2, 2 resimden 2.
    • While using the spatula, slowly get under the top part of the speaker. Then slowly move down the speaker to detach it from the device (there is a small amount of adhesive).
  3. Sprout Channel Cubby Speaker Replacement: adım 3, 2 resimden 1. Sprout Channel Cubby Speaker Replacement: adım 3, 2 resimden 2.
    • Remove black tape.
    • Disconnect the red and black wires which are soldered to the device. Make sure to not remove the wires that connect to the battery.
    • Replace the speaker.
    • Follow the steps in reverse order (be sure to solder the wires correctly) to install it.
Sonuç
Bir başkası bu kılavuzu tamamladı.
jasen biggins
741 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 14-101, Meier Fall 2015 USF Tampa, Team 14-101, Meier Fall 2015 üyesi
USFT-MEIER-F15S14G101
4 Üyeler
12 adet Kılavuz yazıldı
2 Yorum
Jasen, where can I purchase the replacement speaker for the Sprout?
william mulligan - Yanıt
There is no way that I would want to take apart a new tablet to replaceor repair the speakers. Why not install it correctly the first time? Appears to be an ongoing issue.
Edreia Jones - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 12
Her zaman: 1,069
