Giriş
This is a fairly simple guide the only thing that is needed is the plastic spudger. The trim usual gets damaged from drops and will need to be replaced accordingly.
Neye ihtiyacın var
Use an opening tool to push in and release sixteen small plastic clips around the edge of the case. As the clips are released, gradually pry the case apart.
There are 19 tabs that need to be pushed out of the inner trim. The metal spudger works great here.
Bir başkası bu kılavuzu tamamladı.
