Ana içeriğe geç
Spy Gear Video Walkie Talkies Camera Replacement
Neye ihtiyacın var
  1. Spy Gear Video Walkie Talkies Camera Replacement, Top Cover: adım 1, 1 resimden 1.
    • Remove the battery cover by removing the P1 Philips screw.
    • Remove the 3 AA batteries by hand.
  2. Spy Gear Video Walkie Talkies Camera Replacement: adım 2, 1 resimden 1.
    • Unscrew Top Cover with a 3mm Triangle driver bit from the Driver Kit.
  3. Spy Gear Video Walkie Talkies Camera Replacement: adım 3, 1 resimden 1.
    • Use Opening Tool to release barbed latch on top cover.
  4. Spy Gear Video Walkie Talkies Camera Replacement: adım 4, 1 resimden 1.
    • Release pilot studs near the hinge with Metal Spudger.
  5. Spy Gear Video Walkie Talkies Camera Replacement: adım 5, 1 resimden 1.
    • Once the Top Cover is free, you will have full access to the circuitry.
  6. Spy Gear Video Walkie Talkies Camera Replacement, Camera: adım 6, 1 resimden 1.
    Bu adımda kullanılan alet:
    Satın Al
    • Use Tweezers to remove the side button.
  7. Spy Gear Video Walkie Talkies Camera Replacement: adım 7, 2 resimden 1. Spy Gear Video Walkie Talkies Camera Replacement: adım 7, 2 resimden 2.
    • Release the zero insertion force (ZIF) connector.
    • Pull the ribbon cable away carefully.
  8. Spy Gear Video Walkie Talkies Camera Replacement: adım 8, 1 resimden 1.
    • With the ribbon cable free from obstructions, use a Prying Tool to release the circuit board from the guide studs.
  9. Spy Gear Video Walkie Talkies Camera Replacement: adım 9, 1 resimden 1.
    • With a plastic Prying Tool, separate the screen from the mounting tray.
    • Adhesive between the layers may provoke damage to the screen or tray. Take your time.
  10. Spy Gear Video Walkie Talkies Camera Replacement: adım 10, 1 resimden 1.
    • Once the screen is completely folded away from the mounting tray, release it from the circuit board by hand.
  11. Spy Gear Video Walkie Talkies Camera Replacement: adım 11, 1 resimden 1.
    • Release the back of the mounting tray using a plastic Pick to unhook the barb from the circuit board.
  12. Spy Gear Video Walkie Talkies Camera Replacement: adım 12, 1 resimden 1.
    • Now remove the mounting tray complete with camera and ribbon cable attached by sliding away from the screen.
    • You must not damage the screen or screen ribbon cable in this step.
  13. Spy Gear Video Walkie Talkies Camera Replacement: adım 13, 1 resimden 1.
    • Discard faulty camera and mounting tray.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
James French
151 İtibar
1 Kılavuz yazıldı
Ekip
IUPUI, Team 7-7, Wilson Spring 2016 IUPUI, Team 7-7, Wilson Spring 2016 üyesi
IUPUI-WILSON-S16S7G7
5 Üyeler
4 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 16
Her zaman: 700
